1981 12v. BJ60 parts
Greenfield, MA
Website
thecarpentryway.blogspot.com
Hello fellow Van Islanders,
I'm selling most parts out of 1981 BJ60, Canadian spec. I had the whole drivetrain available, but no one seemed interested, so I am now willing to break it up further.
There is a minor oil leak from the head gasket, passenger side, which the previous owner said had been there the entire time he owned the truck (about 7 years). Apparently this is not an uncommon 3B issue. The previous owner never stripped the engine or messed with it at all, and changed the oil religiously. I drove the truck about 15 km home, and it ran flawlessly. The truck is a 12v truck, with two 12 v batteries in parallel. Too bad the bodies on these trucks disintegrate so badly.
-engine has about 440,000, runs really strong: $700. Injectors were rebuilt about a year ago, and at that time new glow plugs were installed. Injector pump works perfectly; EDIC is disconnected. Clutch is included, as is water piping, viscous fan, belts, hoses, etc.
-starter, less than 1 year old: $150
-alternator w. built in regulator, less than 1 yr. old: $200
-recent engine mounts: $50
-The 5-speed H55f was put in 4 or 5 years ago and came, unmodified, out of an '86 BJ60 w. 3B. The tranny probably has 250,000 km on it, has no leaks or weird noises. Shifting is crisp and smooth: $1600 Includes reversing light switch, tach sensor, and shift lever
-transfer case NOT included
-speedo cable: $15
-clutch slave cyl.: $20,
-transmission and transfer access plate, incl. lever boots: $30
-main glow and EDIC relays: $30
-dash speedo and tach unit: $30
-excellent chassis, steering column (manual) and suspension components
-brake and clutch pedal assembly: $40
-Toyota 3B factory engine manual: $50
-semi-floater rear axle, incl. drums: $100
-parking brake: $25
-front and rear driveshafts, w. u-joints: $40/ea
-radiator (re-cored unit, no leaks) and shroud: $75
-steering assembly, tie rod, trailing link, etc, complete: $100
-manual steering box and tilt steering column: $100
-front axle, NOT including disc brakes: $50
-dash pad: $25
-gas tank: $40
-sedimenter: $25
-vacuum tank w. sender: $30
-chassis: $300
-windshield washer motor: $25
-multi-spoke white wheels, excellent rubber: $50/ea
-electrical components, relays, etc: Price upon request
Pictures available of most parts. PM me with your e-mail address for pics. For parts not listed, please ask. Prices negotiable if you are buying more than one item. Located in south Duncan, Vancouver Island.
Cheers!
you have PM:)
