1980 FJ40 for sale
Big D
OK, i have found the Fj62 i want to get so i need to sell the 40 first. This is a 1980 FJ40 with a build date of 02/80. This has been my DD for the last two years and i have done alot of work to it with some still left to be done but not much. I bought 2 years ago from another member for $5500. It shows 119K on the ODO but that isn't accurate. It didn't work for awhile till i got that all fixed. It probably has 130-140 on the original 2f. Like any old 40 she does burn oil and does have the normal oil pan and rear main leak. I have a replacement OEM seal for the rear main. She is desmogged running a motorcraft carb. Several people run these on there 40s. It has an electric fuel pump that i have a on and off switch connected too. She has gotten me to and from work without any issues. The tranny works fine and there is no slipping with the clutch. The t-case has been rebuilt with new gaskets and bearings as well as a new idler shaft. The pass side knuckle has been rebuilt and the drivers side needs it done. I have the replacement kit for that as well as inner and outer bears to go with it. The rear axle does need to be rebuilt as it does leak a little by the drum brakes. The tie-rods need to be replaced and i have a comblete set to for that. The major things i was looking at doing this winter is extend the brake lines, driver side knuckle, rear axle, rebuild the front drive shaft. The gas tank does have a small leak and i have a replacement for that as well. Doesn't cause any issues as i only put in a half tank at a time until i replace the tank. Does have a soft top and soft split doors. No hard doors or top. I do have a bikini top for it as well. Has bench seat in the rear. Has a 4" HFS lift sitting on 35's (30% tread left) on chrome rims. Have full size spare as well. HFS shocks all around and greasable shackles and spring hangers. I have ever receipt since i have bought it as well as a FSM to go with it. She is rust free minus a dime size hole on the pass sill above the step. Below are the items that have been replaced since i have owned it.
front calipers
brake master
clutch master and slave
rebuilt starter
rebuilt alt
thermostat
completely rewired the rear hardness
rebuilt tranny
pass knuckle
besttop super top
bumperettes
bolts and other misc parts
front bumper
chrome side mirrors
I do have numerous parts that will go with the truck. She has been a good truck and i think i have decribed her as best as possible. Many of you have seen her and her transformation over the years.
If you would like to come and take her for a drive let me know as i live in richardson.
The picture is of her before i changed from black to chrome rims. Let me know if you have any questions.
The price is $6k and so to save you time i will not be going any lower that that. I think she is priced right.
Jason
