1977 2F Engine Seal Kit
Will Van
GOLD Star
Austin, TX
The previous owner of my 1977 FJ40 2F had the motor rebuilt/machined, but resealed everything himself. He did not do a very good job resealing, and the motor was leaking oil from the front and rear crank seals and possibly the oil pan. Plus leaking coolant from the thermostat housing and coolant inlet/outlet. I decided to tear everything back down and address the leaking fluids, because a leaky motor drives me insane.
I purchased a full "made in Japan" gasket overhaul kit from fjparts.com and it appears to be high quality. I don't need all of the gaskets in the kit, but I purchased because it included absolutely everything I would need no matter how far I tore down the motor.
However, after realizing how much work this is to tear down the motor and access all the seals, I'm debating if I should just get all new Toyota gaskets and seals.
What do you guys think? Is the gasket kit I have good enough?
Also, which vendor is a good source for a complete Toyota OEM gasket kit?
