Build 1976 FJ40
North Bend, WA
Decided to post a build thread here instead of "what I did today"
This is how I got it as parts for my 71. My 71 has since been sold.
I started working on it about 2023 (bought in 2005)
Decided to freshen up the "rebuilt" 350. Found it had to have at least 50K on it, so went deeper into it.
Got it moved under the carport. Did not like the bobbed rear frame or the welded on body lift blocks.
Pulled the body off, and stripped the suspension.
Sent frame out for sand blast.
Back from sand blast. More than expected, $450.
Welded blind nuts into the "new" rear frame.
This has been treated with POR15 etching solution
Installed button head bolts into places where I was not able to drive and buck rivets.
Painted entire frame with POR15. Bare spots are anticipated welding for motor mounts.
Installed new brake tubing on front axle.
Made and installed new brake tubing to frame. The fuel lines will be replaced after trans mounts installed.
Discovered bad rust below both A pillars.
Found a front cowl in good condition (no rust) and bought it. About 900 serial numbers before mine.
Stripped cowl down to prepare to connect to tub.
Cut old cowl off of tub, and prepared tub for new cowl.
Painted the firewall, and installed the clutch master cylinder.
Bent and installed the clutch and brake tubing.
Used a 32mm impact socket to make the coil bends to the frame (closest diameter I had to the OE coils).
Did not have the booster/master cylinder yet, so that part will be bent up later (4 wheel disk brakes is what I want)
