1975 FJ40
Oregon
Hello!
I will apologize upfront for using the wrong terminology and nomenclature in post.
I am new to FJ40’s, though I have had mine for 20 years. I am just getting around to it. I have been traveling to less than friendly places - Gone for a year home for a year and so on, but I am now retired from that.
I own a 1975 FJ40 that came with a Chevy 350. I just had it stripped down to the frame. The engine is being rebuilt, the frame has been sandblasted, the common rust spots (Mild) are being repaired and it is going to get new everything (“New everything” might be an exaggeration but my wallet feels that way).
1. I am adding four wheel disc brakes but not sure what to buy. Suggestions? If it comes with a single cup master cylinder is that a problem? It has a dual cup right now.
2. I bought a Man A Fre Saginaw power steering kit. Any pitfalls I should be aware of?
3. I bought a 2” OME suspension kit. When I bought the FJ it was a spring over axle lift. Any concerns on just making it an OME lift - i.e. steering length, driveline length, something I’m missing?
4. I want to put an automatic in it and no a lot of people will be against this idea. Any suggestions on how to or what to put in it? Please know that I am disabled and a lot older so I would prefer an automatic.
5. If an automatic is not possible or cost prohibitive, can I change the gears in the axles for “highway gears”. It has 33” tires but I do want to take those down a bit - maybe 31’s.
Please be kind in your response...
Sounds like a cool project, glad you didn't give up on it after owning it for 20yrs! Do you have any pictures before the tear down, I think it's safe to say that everyone like pictures!...Sorry that I can't offer you any advice on your questions as I am new to FJ40's myself, but I do look forward to seeing your progress, I could use a little inspiration and motivation for my upcoming build!
Here are some photos of the process.
Sounds like you have a solid laid out plan.
1) Some masters work, other don't. On my old 75, I used a mini-truck front end to convert the front to disc brakes(ie knuckle out swap) and the typical El Dorado 1/2 ton Chevy rear disc brake swap. I used the stock 75 master(two reservoirs) and a proportioning valve. No issue stopping 35s. Took a while to get it dialed in front to rear though :/
2) I'm not a huge fan of the Saginaw conversions that butcher up the front crossmembers. That would be the only pitfall. Some don't care for the 'over boosting'. I used the typical 4 bolt, 4 turn box on my old FJ40 the first time around. I converted to a Scout Saginaw PS conversion because I hated the look. My FJ55 has a Scout Saginaw conversion. Does well on the road and at freeway speeds.
3) You are going from ~6" of lift(SOA) to 2". You will have drive shaft changes at a minimum. If your old SOA was done properly, you may have to address steering linkage that may be in the way.
4) It sounds like you have typical carb'd 350. I can already hear the scream for a 700r4. You couldn't pay me enough to run one... known weak tranny that takes money to fix the issues. Short of running a manual valve body or tracking down an 'expensive' transmission 'computer', none of the newer OD trannies are viable... unless you swap to an EFI engine ;) There is also a length issue. A Ranger OD box is out of the question. Maybe Turbo 350 plus a Fairy OD on the tcase??
5) If you are going to 31s, why did you buy a lift? :hmm: And if it was SOA for 33s, I'm also confused. FWIW, I believe the 'highest' gear ratio you can get for an LC third member is 3.7x. I think there was an ultra rare early 1960s 3.5x gearing. But then you get into weak coarse spline pinion.
Maybe I just need to simplify.
1. I’ve been looking 4 wheel disc brake “kits” that come with a master cylinder. Anybody have experience with this?
2. I bought a Saginaw from Man A Fre, anything to look for on installation?
3. OME, 2”, any installation concerns or tips?
4. I don’t know what a 700r4 is. Will that work? Two reasons for this - a). I am slightly combat disabled (Knee surgery, two hip surgeries, lower back surgery, fused neck surgery, shoulder surgery, and split heel bone) - it retired me after 23 years. b). Wife does not drive stick but I could teach her.
5. I’m going to drive it a lot so if the transmission can’t be changed I would like gears that are easier on the highway.
Looks like you have a nice solid FJ40 to start with, looks really good! A 700R4 is a Chevy
3 spd automaticc transmission with an overdrive. I don't have any experience with them personally, I always had turbo 350 or turbo 400's. Depending on your final tire size I don't see why a turbo 350 or 400 wouldn't work for you, maybe someone else will chime in.
