SOLD 1974 fj 40 restore or resto mod
Status
Not open for further replies.
Colorado
fj 40. Great for Restore or Resto mod. Body in decent shape rear sill and rear doors rusted. floors rough butsoild. have frt seat frames and one rear jump seat. I have started a Patina restore on it all ready. axles have had a stage 3 restore frame is partially restored
frt axle
Complete restore . upgraded to fj60 disk with 6x big brake upgrade .new calipers , pads, rotors and hoses from napa. custom bent stainless steel brake lines complete knuckle rebuild with koyo wheel bearings . stock gears open diff. painted in a satin black epoxy. oem hardware re zinced
rear axle
Complete restore up graded to caddy rear disk brakes with e brake. brand new calipers from speedway. napa rotors. new axle bearing and seals . stock gears open diff. painted in a satin black epoxy. oem hardware re zinced
Chassis
Trailgear 2.5 lit.
proffitts shackle reversal in frt
rear springs flips for added wheel base
fj60 power steering box with frame reinforcement
I bought this with a sbc v8 conversion was planning on rebuilding it the same . Frame has all oem mounts so it could be taken back to stock. comes with oem 4 speed and t case the advanced adapter kit for it and wheel well headers.
I also have a 1969 high nickel 4 bolt main 355. 202 64cc heads and a roller valve train.contact for details engine is not included in price
new house means this one has to go.
10k firm firm firm just the axles are worth that
frt axle
rear axle has fj 62 fine spline ring and pinion also have one for frt not installed
Status
