SOLD 1972 FJ40 - totally dismantled, opportunity to take over a project halfway through
Status
Not open for further replies.
Chicago, IL
  1. 40 Series
I have a completely disassembled 1972 FJ40 in Chicago, IL. And when I say completely, I mean diffs, axles, door hardware all disassembled.
After years of starts and stops, covid and getting married, etc etc, it is finally at the point to reassemble, paint, etc. But life has changed and I've lost my passion for this build. I am hoping someone will be interested to take over everything I have and put in the work to finish it or use parts for their build.
Here is a link to lots of pics of what I have. FJ40 parts - FJ40 parts - https://photos.app.goo.gl/4T4vwj1jZpGwmwk89
Not pictured is a brand new Aqualu 3/4 1968-1978 tub which is still in its shipping plastic/wood corner frame. Also not pictured are new, OEM fenders, also in the box they were sent in.
I started pulling together a list of everything and included below my list so far.
I am hoping to sell everything altogether first... If that doesn't work out, I will proceed with a part out.
I am asking for $15,000 for every land cruiser part new and old that I own. If you bring a trailer I'll help you load it up.
If you don't want the Aqualu tub, I'd be happy to discuss if you want everything else (just note, I don't have the original tub anymore).
I am open to offers and discussion. Just pm me and happy to chat on here or talk on the phone.
PART LIST
3/4 Aqualu Tub, New still in packaging (box not in the massive box if initially came in)
1972 Frame with Title. Frame had professional welding work done (moved the center cross bar back to accommodate 2F and 4 speed trans, welded on FJ60 power steering box mount, added Ford shock towers to fit power steering without (or with minimal) fender modification needed, removed welded on aftermarket stuff to bring it back to stock. Then it was hot dip galvanized, then powdercoated black.
New OEM front fenders (x2)
Old fenders (x2)
Rear lift gate with glass and top reinforment bar
Transmission tunnel
Front and rear axle housings
Front seats (driver & passenger)
SOR 310-72D seat covers
Toyota 87901-60020 (Passenger Side Mirror Assembly Outside Rear View) x4
FJ60 Knuckle Components (both sides)
Differential housing
FJ40 steering arms
Air cleaner
4 sp transmission with "3 speed" t-case (from 1974) rebuilt by Darrel Noorda
Air cleaner #2
FJ40 heater box
FJ40 heater blower motor
FJ40 roof
Glass (rear sides, rear window, windshield [cracked], doors)
Refinished FJ40 steering wheel and horn press
Boxes of refinished pieces... bolts, axle parts, diff parts, pedals, etc etc. Probably 100 lbs of parts
Reproduction (from FJ40GURU) dash pad set
New OEM rotors for FJ60 knuckle and disc brake setup (43512-60010) x2
New OEM courtesy lamp (81370-60010)
Front and rear heater radiator cores (cleaned and cadmium coated, not leak tested)
FJ40 brake and clutch pedals
Differential and axle seals, gaskets, and hardware
Toyota reman. FJ60 calipers (47730-60021-84 and 47750-60021-84)
New OEM badges, badge kaskets, shifter knob, and various pieces of hardware
Trail Tailor Knuckle Centering Tool
New OEM front bumper gussets (52116-60010) x2
FJ40 mirror arms x2
FJ40 wiper arms x2
FJ40 wiper motor / link assembly #1
Cruiser Outfitters - 2 course spline pinion flanges, FJ60 knuckle rebuild kit w/Koyo bearings, axle snap rings
Mark Baker (aka Coolerman) rebuilt front and rear wiring harnesses
Gauge cluster parts (frame, gauges themselves)
Many Toyota OEM parts (windshield wiper switches (x2), high and low horns, 4WD ornament, rear lift gate handle and pad, and various hardware). Ask for a further detailed list.
FJ60 rebuilt power steering pump
Hood, doors, aprons, hard top sides, rear swing doors, bib and grill. All were cleaned of rust through a dip stripping process and had a coat of primer.
1F engine
original 3 sp trans + t-case
I have bought parts from Vulcan before, a complete drivetrain in fact, and if he says something is in good shape, it is, and he was great to work with on shipping and everything.
What are you asking for the mirror arms? (item 23) and the heater lines/grommet that go through the firewall.
Status
