1968 fuel tank feed
Whispering Ranch Az and SoCal
Lads,
I am in the process of restoring the fuel tank on the '68. The feed hose to the fuel pump will be replaced. What is throwing me is the connection compresson fitting on the hose that connects to the tank. It doesn't appear to be able to be used again I cannot remove the hose from it anyway. Soooo...that is where I am.
A new compression fitting would be nice but I haven't been able to find one. The next step is a fuel nipple that has a threaded nut on the one end as to screw it on to the tank.
Any tips on where to purchase something like that would be helpful. All of this would not be a problem but the metric size is the stumbling block.
Regards
Yea Pricey ! You can order the nut from Toyota nut part # is 90402-13041 and then get this part from the hardware store McMaster-Carr 5/16 is the correct hose size but if you open the nut a tad you can use 3/8
JP
I got the one for my 68 from SOR. Yes its expensive. Its a compression nut type of deal with a fuel line in the enter. Yes, you wont find a comparable part in the fittings section at Lowes or a auto parts store. I would never mod that particular part since its a part that flows gas right under your butt: Get the right part
A little update concerning the fuel line attachment (if anyone cares). It can be saved as it is just a compression fitting. So I heated it up just enough to soften the old fuel hose and it came apart. Now all that is needed is new clear fuel line. BAM..........
The heating process was done with friction. spinning the nipple on the end of an electric drill with drill bit inserted. Will see if it seals tight when re-attached. It may be all for nothing but certainly worth a try.
Please keep us updated! My original fuel line is intact and in fairly good shape, but I’d like to learn of a close to oem retrofit!
I would have been wise to place the fitting in very hot water to soften the old fuel hose for removal. The drill bit was a bit hasty but it worked. Hopefully I didn't damage the bevel on the nipple. To add to this, remember, if you have the original clear fuel line from the tank to the fuel filter, it's old and may be brittle. Sooo, there is that. Just a thought.
I don't remember how many Porsche 356's and Gen 1 Broncos we have done finding "ready to go" fuel lines. Safety first.
If this is the two piece fitting, barbed nipple with a convex seat and female threaded nut that secures it, then I have some
1900668
