Hey all I had some questions. I added a brake booster to my 67 fj40.
I used a booster and single reservoir master cylinder off of a 81 mini truck I also have 1971 Fj40 axles with mini truck knuckles and disk brakes up front with drums in back. I ran all new brake lines and have good fluid pressure to all 4 tires. I adjusted my plunger rod all the way to the back so that I have a 1/4in of play in the petal before the brakes engage when the vehicle is OFF but when I turn the vehicle on and pull vacuum the petal is as light as a feather and when I press it all the way down the rear drums engage and lock up but the front brakes don’t do much. The plunger rod as stated above has a 1/4 inch play when vehicle is off and it is adjusted all the way to the end of the threads towards the booster side.
Anyone have any suggestions?
Thank you.
Thank you.
