- Vehicle Model
- 25 Series
- 40 Series
- 45 Series
- 55 Series
An original Toyota large canvas tool roll and vintage Toyota tools.
Asking $799, including shipping. Shipping to US only. Please PM to discuss.
This Land Cruiser tool roll includes the assortment of tools found in kits during 1963-64. During this period Land Cruisers changed from 23mm to 21mm lug nuts. This kit includes the 21mm lug wrench. All tools are vintage Toyota. A replica Content List replaces the missing original.
Overall the tools are in good, used condition and have marks and wear from age and use. The grease pump appears unused. There is rust on the wrench clip, the small (75mm) screwdriver ferrule edge is bent, and there are stains on the blades of the feeler gauge. The spark plug gap tool is an earlier version with 2 loops (0.7mm/0.8mm), rather than the 0.9mm type with a single loop. The original finish early jack handle has chips and scrapes.
The tool roll canvas is in good condition. There are several holes in the upper and lower flaps and main canvas. The canvas has typical marks, stains and grime from age and use. The plastic in the Content List window is missing.
The kit includes the following pieces:
More images here.
- Maruki brand hammer (1lb), with the Maruki logo and #1 marking
- Pliers (200mm) with TEQ logo, marked M.PAT, with dimpled grips marked Made In Japan
- Lug wrench (21mm) 1-piece, marked Toyota Motor and Made In Japan
- Adjustable wrench (250mm), marked Toyota TEQ Motor with oval pad
- Spark plug wrench (20.6mm), marked Toyota Motor, formed socket with loop handle
- Screwdriver (150mm), wood handle, flat blade, marked Toyota Motor on the shank
- Screwdriver (75mm), wood handle, flat blade, marked Toyota Motor on the shank
- Screwdriver (100mm), wood handle, No.2 cross-head, marked Toyota Motor on the shank
- Wrench set with blue TEQ wrench clip
- Open-end wrench (8x9mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (10x12mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (12x14mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (14x17mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (17x19mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (21x23mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Blue TEQ wrench clip (6-wrench set size)
- Grease pump, marked Toyota TEQ Motor and Made In Japan, with straight nozzle and curved nozzle with chuck
- Engine Adjust Kit, green vinyl pouch with TEQ logo and Made In Japan, containing:
- 5-leaf feeler gauge (.006, .008, .010, .014, .018, marked metric & (inches))
- 7x8mm ignition wrench marked 09855-10021
- 0.7/0.8mm spark plug gap tool
- yellow handle spark tester screwdriver marked TEQ
- red handle points file
- Post-August 1963 large tool roll canvas, with full length strap, working slide buckle and replica Content List
More images here.
