- Vehicle Model
- 25 Series
- 40 Series
- 45 Series
- 55 Series
A Toyota Land Cruiser tool kit from 1960-61, including an original tool roll canvas with original tools. The canvas marking MADE IN JAPAN on the front flap is very unusual. Several of these early tools have design or markings that are noticeably different from tools supplied in later tool kits.
Asking $1499, including shipping. Shipping to US only. Please PM to discuss.
The tools are in very good used condition and have marks and wear from age and use. The canvas has 2 holes near loop #1, a small tear to the right of loop #9 and 4 very small holes on the upper flap. The canvas is stained near loop #1, with small stains elsewhere. The slide buckle is missing most of the paint. Overall the canvas is in very good condition. The Content list is original and correct for this kit. This kit does not include an Operation Manual (Owner's Manual). Considering its age, the condition of the canvas and tools is quite remarkable. See a contrasting example at the end of this posting.
The kit contains the following items, including some rare pieces, which are marked with an asterisk:
Early tool kits from this period are not all that common. And those that do exist are not necessarily in prime condition. To compare, here's an example of the same type of kit (not mine) in somewhat rougher condition.
- Maruki brand hammer (1 pound), with Maruki logo and marked #1
- *Pliers (200mm) with TEQ logo, curved handles and triangles grip
- *Lug wrench (23mm), 2-piece, marked Toyota Motor
- Adjustable wrench (250mm), marked Toyota TEQ Motor with oval pad
- *Spark plug wrench (20.6mm), marked Toyota Motor, recessed socket with loop handle
- Screwdriver (75mm), wood handle, flat blade, marked Toyota Motor on the shank
- *Screwdriver (150mm), wood handle, flat blade, marked Toyota Motor on the shank and MADE IN JAPAN on the handle
- Screwdriver (100mm), wood handle, No. 2 cross-head, marked Toyota Motor on the shank
- 6-wrench set with blue TEQ wrench clip
- Open-end wrench (8x9mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (10x12mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (12x14mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (14x17mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (17x19mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Open-end wrench (21x23mm), oval handle, marked Toyota TEQ Motor and Nickel Chrome Vanadium
- Blue TEQ wrench clip (6-wrench set size)
- *Grease pump, early version with no side port, marked Toyota TEQ Motor, and curved nozzle with chuck
- *Straight nozzle for grease pump, early segmented version
- Engine Adjust Kit, green vinyl pouch with TEQ logo, containing:
- 5 pockets
- 5-leaf feeler gauge (.006, .008, .010, .014, .018, marked inches)
- *8x9mm ignition wrench marked BX-SST 1001-6 and Nickel Chrome Vanadium
- 0.9mm spark plug gap tool
- yellow handle spark tester screwdriver marked TEQ
- red handle points file
- *Pre-August 1963 style, large tool roll canvas marked MADE IN JAPAN, with full length strap and working slide buckle
- *Original Content list
