17x8 Wheels (Not Sequoia)
Nay
Colorado
I know Sequoia rims fit, looking to avoid spacers (both cost and requirement). I can't seem to find any selection of 17x8 rims, with zero offset max, -6 to -12mm preferred, for the 80 due to hub diameter and required bore size.
Anybody have any aftermarket rims that you know work? I am hoping to move to 37x12.5x17 Nitto Terra Grapplers, with a future set of Iroks or something for crawling and deep snow use.
I am tired of one tire for all uses - I spend most of my miles on the road, big trips are desert wheeling such as Moab where the Nittos will be very good, and for 6 or so crawling trips a year and the occasional blizzard or snow run I can eventually run some Iroks.
My Gen II FOR kit is built for 37's, been wanting to do this for awhile, but I need to nail down rims.
Thanks :popcorn:
4wheel parts has what seem like hundreds of rims in 17x8 w/ 0 offset and 17x9 w/ 6mm offset.
On their website do a search under 17x8 or 17x9
hey!
May be this helps , I'm running this fj-cruiser 17x8" steel wheels BFGm/t 25575 r17 not too expensive... I pay about $50 each
:cheers:
Those FJC steelies aren't the offset he's looking for, but recentering probably costs nearly the same as spacers.
Can anyone confirm or deny that?
So, just to make sure I can do math... Nay, you are looking for a 17x8 with a 3.5" - 4" backspacing, correct?
Ideally I'd say 3.75"-4" backspace to set the wheels out .5-.75". 17x7.5 is ok, too, 17x9 and you are starting to get too wide.
There are lot of rims out there, but it's the 80 series hub bore that knocks most of them out.
FJC steelies are an option, but they don't move me since I'm really looking at going to two sets of tires if I go 17" with Terra Grapplers. A heavier steel rim would be the choice for the offroad set, not the AT set. Steelies add $20 lbs a rim over alloys, which would more than offset the lighter AT's in total wheel/tire weight.
I can get a set of 17x7.5 FJC alloys for $250, but I don't have a clear picture on the backspace of those rims for '07/'08.
The other choice will be 37x12.5x16 Trxus on stock rims and I'll shine up the frame until I decide to do 1" spacers. That is the easy choice...all of this assuming I can sell my Toyos, because nothing is selling well right now.
Discount Tire Direct has 37x12.5x17 Terra's for $305 right now, great deal if they just had a good rim, too :bang:
With bigger tires there is less margin between rubbing the outside lip on straight compression and hitting the inside on flex. In my experience narrow tread width is key.
Mine adds up to ~3.25" backspace on a 7.5" rim, works well with my setup, has never hit. When they were first installed/setup there was plenty of room. After lowering the shock mounts, the added flex angled the tires in when fully flexed bringing them very close to the wheel well.
IMHO the amount of flex, axle/tire angle make the most difference, but bump stops, shock/suspension travel, wheel backspace, tire/tread/rim width, so each suspension is slightly different.
I have no experience with your setup, but IIRC you have less droop, so my guess would be somewhere in the 3.5-4" range? Given the choice I would rather hit the inside, most times this is done low speed and contacts a relatively smooth surface. Outside hits are more often done at speed, hitting the relatively sharp fender lip, so more chance of damage?
All of the FJC rims that I have measured have more backspace (closer to 5") so moving in the wrong direction.
I don't get the two sets of tires thing? IIRC you only run the rig ~5000mi a year, even something like Iroks should go the distance, Grapplers would have most of their tread when timed out?
If you find a nice set of wheels you like, don;t let the hub bore worry you too much. I had to bore out my H2 wheels to fit on my 60 a while back. Anyone with a lathe, or engine bore, or even a steady hand with a grinder can open them up for what you need.
Yea, I'd like to put more miles on it taking trips to cool places...more of a "Cruiser" if you will. I've spent the last 3 months glued to a desk, getting a bit of cabin fever these days thinking about spending time out in Utah. I have typically put 7,500 a year on my rig, and even though I am saying 37's, I am starting to get a real goal of wanting it to be quiet as possible so we'll use it more as a family (as in WTB stock resonator :D).
The Grapplers would be to have a really nice and smooth 37" tire, well mated to the 5.29's, and lighter than any 35" MT I have run, with good performance in the largely dry conditions I see and very good in winter unless it's a deep blizzard. I'd probably do 25K in 3 years and still be able to sell them for decent coin. It's the deep snow I see from time to time that gives hesitation more than treadlife.
Trxus were about right though, in 2.5 years and ~19K miles they were down to about 50%-60% tread, and nice and quiet, and still saleable for 30% of new ones. Plus they can be run on my stock rims with a 1" spacer...but not lighter and not smoother, not that I have had any problems with getting Trxus balanced.
May not be a decision I have to think much about since my Toyos aren't selling, at least not a price I'm willing to part with them. If you have to drop your price to 50-60% of new with only 2K miles, that's not a value proposition.
I'll probably end up doing the 37x12.5x16 Trxus if the Toyos sell, that's just too easy and I've loved those tires for years. No puns intended, I had ought to stop trying to reinvent the wheel :hillbilly:
Yea, FJC look to be 5", although good with 1" spacer. My setup wouldn't angle quite as much in as yours (less droop), so 3.5" to 4" would be right on.
The Toyos are so wide, I wonder if a narrow 37 would really be much worse even on stock BS? The Trxus tread width is something like 9.2" on the 37's.
... I've spent the last 3 months glued to a desk, getting a bit of cabin fever these days thinking about spending time out in Utah. ...
I'm in the same boat, last trail day was new years, starting to go a little crazy (or more crazy)?!:o Looking forward to 9 days of Cruise Moab!:cool:
That's one concern that I have with the new Grapplers, all Toyo products that I have measured tend to run on the large/wide side. Haven't seen them yet, but have been carrying a measuring tape, in case the sighting happens.:hillbilly:
Is the Trxus width published or have you measured them? The Coopers were the narrowest that I could find at slightly over 10" tread. I don't put much trust in the published numbers, they are all over the place, some big, then there's BFG at almost the next size smaller.
Trxus is a published spec - I'm not sure that are that narrow in total, but the outer lugs are curved up just a bit, so I'd say contact patch is that narrow.
They do seem to get a bit skinnier as they get taller, my 35's looked skinnier than the 33's.
They are way skinnier than Toyos at the tread point, and you are dead on that on a smaller lift you need a skinnier tire so you don't start hitting the fender lip as you stuff.
Here's a pic of Trxus next to a pic of a 35x10.5x16 SSR, which is a good reference. I think Interco is measuring across those "inner outer lugs", because that is the actually tread contact with this tire, whereas the you can see the tire is wider.
You fellas need to get out more. We're hopefully headed to Moab for our second trip of the spring this weekend.:grinpimp:
I'm gonna go with the Trxus 37x12.50r16s on my MT rims and see what happens. Now I just have to finish the fire sale of my minitruck to free up the funds.:doh:
I threw out my 35 MTRs last fall to ensure new tires this spring, and my 33 studded mudders are driving me nuts on 4.88s (now I know how Nay must feel with 5.29s and 35s). The saving grace is with my SC, 4.88s, and 33s, I feel like I almost need a wheelie bar.:lol:
Anyways, good luck with the rims Nay. Let me know what you come up with & I'll see you all at CM09.:steer:
Nick
Nick
Post up on the tires once you get 'em.
I've been looking since you first posted this.
It seems the bottom line is two of your requirements conflict:
Backspacing and material.
There are plenty of 17x8 alloy rims with the wrong backspacing.
Steel wheels can be ordered in any offset, but are very heavy.
The amount of backspacing you want on an 8 inch rim seems to be available only in 15 inch diameter.
So what is the higher value - weight, or not using spacers?
I think you are right - 17" rims tend to be deep dish, because OEM 17" are deep dish.
Higher value is the road orientation of alloys with spacers than the weight. I could get 5 FJC alloys locally for $250 right now and add 1" spacers to be perfectly backspaced, so it's not a big deal, that's only $420 for the wheel setup in total.
Reality I think for 17" rims is you want the higher backspacing so you can space it out to your desired fitment, if you can find rims inexpensively. That's what I'll do if I go to 17's.
