Iv search a lot and found some options but nothing in aluminum yet. And actually nothing local but doesnt have to be local. I'm searching for 17" wheels 7-8 wide that will fit my 75 truck needs to be 3.5 backspace (I dont want spacers). Any advice on a brand to look at or toyota part numbers would be great. I found this part number 42611-60B70 and 42611-60B71 which is I believe 17x6.5 6x5.5 lug 3.5BS. and I will probably go with it if nobody else can help. I would like a little wider like 7"-8" wide. I just don't want any wider than 8"
I'm currently running 35x10.5 on some procomps that aren't machined correctly and they are square rather than round
. and it's not the balance of the tires. They also need 1/4 spacer for caliper clearance which is frustrating cause they are 3.5 backspace.
I was searching for aluminum cause I'm told they balance out better than steel. I'm hesitant to buy more steel rims cause I'm worried they will also not be round. Although I believe stock toyota rims should be made with better specs. Any help to steer me in the right direction would be great.
My thought is if they made stock 17x6.5 for the hilux (05-15) and prado (06-15) depending on various models and European/Middle east. Perhaps Toyota did 17x7.5 too with 3.5BS? cause I keep coming across info on 17x7-7.5 but I don't know what they came on or what the BS is. Maybe if I had a part number for a 17x7.5 and 3.5BS I can source and ship em.
