15w-40 oil regular or syn?
S. Texas
I have a '97 with 178,000 mi. It uses oil like a lot of cruisers at this mileage. I usually add 1-2 quarts every 800 miles. It does not smoke or have any leaks. My daily commute is 5-10 min at a time (50 mph max) so I assume this is possibly contributing to the usage. I initially switched to Rotella, then Mobil 1 and sometimes Valvoline Max life - usage has not changed. I have read thru old posts about switching to 15w-40 oil. The only brand I found was Chevron Delo - which is regular oil. Is this what has been referred to in the past? I live in S. Texas and have Advance Auto, Autozone and Wmart to shop. I'm sure the valve seals and possible rebuild is in the future but I do not want to go that route if I don't have to. I also have the P0401 code going - does that contribute in any way to oil usage. PCV valve changed recently. Suggestions appreciated.
Thanks,
Nelson
i say if you have to add 1-2 quarts every 800 miles than its time for a rebuild.
I run Mobile 1 and change every 5k but never add any between changes, usually down about 1/2 qt. by then. 1-2 qts every 800 miles is not normal at all. No smoke usually means valve guides and the oil is burned off while driving.
In your situation a synthetic wouldn't make a lot of sense. I would just find a good deal on chevron delo 15-40, stock up, and see what happens to consumption.
With that kind of consumption you don't even need an oil change you are constantly getting new oil and additives added. Just change the filter ever 3k like normal. But yea you need a rebuild
My local walmart has the Mobil 15W-40 for 10 bucks a gallon. It's a black jug. That's the best price I've seen on it or on the Delo. I do think it's definitely worth a shot for you to try it out. Maybe even a couple quarts of that thick Lucas stuff too.
Chevron Delo 15w-40 at 10k oil change intervals has treated me like this:
1987 ford f350 -6.9 diesel - 400k before sale - still going
1991 f350 - 7.3 diesel - 410k before sale and also still going..
1996 f350 powerstroke -340k before sale - haven't kept track of that one
2001 dodge cummins - 410 k before sale and totaled shortly thereafter
This is just the trucks that I drove from a fleet of 20 plus. We sold trucks at 5 years or 400k whichever came first and never got into a block.
For your situation, it's perfect. Cheap, comes in big jugs, and is stiff enough to slow your leaks some. A seal swelling additive would't hurt either.
Thanks,
Nelson
IMHO, and based on having been a mechanic many years ago, and since I really doubt the physics have chnaged since then, if the rig doesn't smoke at start up, then the valve seals are not the issue. That would lead me to the piston rings, but you should be seeing some kind of smoke behind you at night in the rear view mirror in the headlights of the cars behind you.
All - tell me I am wrong here if I am, but burning through a quart every 800 HAS to be noticeable either at start up and/or during cruise/acceleration. Night time is the best time for the acceleration test.
Unless there is something different about a Toyota head design that I could very well not be aware of, bad valve seals will leak during sitting causing visible smoking at startup.
Are you SURE you have no leaks at 178k miles?? Unless you have done a few gasket repairs, I would find it hard to imagine you don't have a leak given your explanation that you are seeing no smoking from the tail pipe.
That would be a lot to leak out and not have a drop on the ground, I would agree it's your rings, but you don't see a lot of bad rings around here. So I can't be positive but yea it has to be going somewhere, burnt or leaked, so it's going to be smoking or leaking.
Rebuild and synthetic afterward, if not rebuilding for now then use regular oil.:popcorn:
the Delo is good stuff, although some argue the previous gen was better than the current one.
that's what I use to good effect per oil analysis
I vaguely remember somebody reputable here mentioning that 1 qt / 1000 mi was still OK per specs, surprisingly, but not sure if that's true.
Do a leak down test to see what's going on...
Yesterday afternoon I started the LC, (had not been started since previous day around 5 pm) ran to the back and no smoke. The only time I see smoke is during cold weather start up. It does not leak but does have some wetness underneath - like the oil pan gaskets or rear main seal could be changed. I purchased the Rotella 15w-40 as my luck would have it being out of the Delo brand. Any problem using the Rotella? I'm not sure I can afford the rebuild now as it is my DD and I don't have a extra car. Thanks, Nelson
The Rotella 15W-40 should be fine, you could also go with a 20W-50 if the Rotella is also consumed quickly. Toyota states that 'up to' 1 quart per 1000 miles is 'normal' consumption.
I have always run Mobil 1 syn 15W50 with great results. If the bottom of the rig is damp, you are leaking oil or power styeering fluid, or antifreeze or a combo. I would be surprised that your driveway does not support this but anything is possible. Truly, I would be surprised if you need a rebuild unless the rig was severly abused. I could see a tranny, or even a diff given needing to be rebuilt from lack of service, but most owners at least know to change the engine oil regularly.
Maybe consider an engine wash with hot water from your hot water heater drain faucet and some Siple Green or store bought engine degreaser, then see where the fluid is coming from.
Hmm....it's possible that it is burning it, but if you have scrutinized your tail pipe for smoke, I'd simply be surprised to find you need a rebuild when you can;t find the oil coming out of the pipe. I'm stumped based on what you are saying.
we have always used Delo 400 15/40 in my 81 and all the marine diesels here. The old boys would slap me silly ifn' I changed brands...
