It seems that no issues have been reported on swapped 14Bs and 15Bs by cutting the sump (oil pan) wings....my other concern is the sump ( oil pan) I’ve modified it by temporarily cutting the “wing” off that interferes with the front axle, but I really don’t like it, and I think it may cause oil scavenging issues down the line if I left it like this.
Does anybody know if the 13bt sump /
Oil Pan from a Bj74 or similar fit? If not what have others used… I’m prepared to make a custom one if I have to, but I’d prefer a factory finish if I could. View attachment 3069347
forum.ih8mud.com
@Greek CruiserheadIt seems that no issues have been reported on swapped 14Bs and 15Bs by cutting the sump (oil pan) wings.
However, it is possible to use a sump with no wings from a 1988 and later 3B (the so called 3B-II) from any donor vehicle (eg. BJ7X, Dyna, Coaster etc.)
14B in to a 1989 bj73 VM
14B in to my BJ73 VM After owning an LJ73 for 5 years while constantly looking for a BJ/HZJ 73 on Norwegian plates I found one! Actually it seems to be the only HD 73 in Norway. Due to the huge import taxes on used trucks import was not an option. This truck was partly built in Portugal and it...forum.ih8mud.com
I’ve used the original mounts from the b engine as suggested, but I’ve had to swap them side to side in order to help with clearance between the battery bracket that bolts to the chassis and the timing case / power steering pump, I suppose they’ll have to be some more modifications yet..
What concerns me most is the engine seems to be leaning to the left side of the vehicle by 2-3° I wonder if anyone else has noted this when doing this conversion?
I’ve ordered new engine mounts which may account for some of the tilt, so I’ll have another look at this when they show up, my other concern is the sump ( oil pan) I’ve modified it by temporarily cutting the “wing” off that interferes with the front axle, but I really don’t like it, and I think it may cause oil scavenging issues down the line if I left it like this.
The ct26 is the common factory turbo for most older landcruiser diesels. I think the stock 15bft turbo was the ct20b, but not 100%. The ct20b is certainly regarded as a "better" turbo. Will get earlier boost, so more low down torque, and probably lower egt for a given power level. People do recommend the ct26 for the 15b and in general, but it could be said that most people that recommend the ct26 won't have actually compared it to something else.
if you where going to all this trouble would you change the steer Box to a power assisted unit? Seems awful tight in this area now though as she’s left hand drive.
@myusername
That’s great info on the steering setup, I’ll see why I can find, here in the UK 40’s & 70’s are like hens teeth and there aren’t many 60’s left now either, but I’ll see why I can find.
