12V DC into center console
Small Waves, FL
I'm considering bringing 12V off the battery with 10g into the center console. Has anyone routed this into the cab through the gasket around the transfer shift lever? There must be advantages and disadvantages. Did some searches.
Just thinking....
That seems like the hard way to get to the console. I ran mine through the firewall, under the door sill and along the rib under the seats to the center console. Running a wire on top of the transmission and transfer case would be a challenge to me. There are a lot of wires already there so I guess it’s not a bad place to put it.
I have done this utilizing a “fuzeblock” which I mounted on the ECM inside on the driver’s side. It is small and will allow you to have fuse protection and the ability to make it switched on or off simply by changing the fuse position. I added 1 outlet on the center console passenger side upfront, 2 outlets on the back center of the console and the last one in the passenger rear cargo compartment. Do a web search for “fuze block” and you should find it. It was clean and straight forward. Run power from your battery to the fuze block, run power to your outlet coming from the fuze block. Again, it is fused and you can make each outlet switched power or hot.
I followed path in post # 2 and have had no problems for several years. Entry point is a grommet on the firewall as shown in the photo below. Little box on top of battery houses (among other things) a 25A CB that feeds a Blue Sea fuse block under the console.
1917808
Yeah, through the firewall is clean and easy. Obviously you should put a fuse onto that new wire, close to the battery positive end.
cheers,
george.
Yep, BlueSea or RigRunner distribution panels are in order. Just wondering about the path of the cable.
Not in a hurry, but trying to avoid the harness wiring.
No. If I did I'd come through the passenger side grommet in the firewall which is direct and has lots of empty space.
Yeah that’s what I did after I added the second battery. When I went through the drivers side firewall there were a couple of unused nipples on the rubber grommet. I used those and it kept my wiring separate from the main loom.
