For Sale 12HT with Auto Trans/tranfer + optional cable lockers
Kamloops, BC Canada
Website
www.shopraddcruisers.ca
For sale is a 12HT engine with an A440F transmission.
Compression results were done on a stone cold engine - about 10C in the shop during testing. By the end of the test the batteries (on chargers) were starting to get a low, so the actual numbers are probably a touch higher than what is actually displayed due to slow cranking speeds. No valve adjustments were done before or after testing, no oil was added to the cylinders.
Started the test on cylinder #6 - often the lowest one - but looks good, and then from the front into the middle - the low-ish number on cylinder 4 may be a bit off (reading low) as it was the last one tested and the batteries were struggling.
1. 440
2. 450
3. 450
4. 430
5. 460
6. 440
[content removed]
The starter, shutdown VSV, alternator are all 24V
Shipping, brokerage, duty etc. are at your expense.
We can guide you through the paperwork if you want it shipped to the USA.
[content removed]
Located in Duncan, BC.
Please call us for faster service.
Prices in Canuckistani dollars.
~John
Any more 12HT coming up for sale?
