- Joined
- Sep 28, 2002
- Threads
- 558
- Messages
- 8,123
- Location
- Kamloops, BC Canada
- Website
- www.shopraddcruisers.ca
- Location
- United States
This is a custom 4 layer MLS head gasket for the venerable Toyota 12HT engine as found in the Land Cruiser HJ61. I designed this gasket to solve sealing issues in engines running higher boost pressures than the factory setting of ~7-8 PSI (0.5 bar).
I havethree ONE units left in stock $395 CAD each plus any shipping and taxes.
NB 1: your engine *must* be machined and finished to the correct surface RA to use an MLS head gasket. Failure to do so will cause the gasket to not seal, and then fail prematurely.
NB 2: The gasket is 1.4mm thick which closely emulates a compressed factory gasket. The bore is 93.0mm. The gasket is viton coated, as is normally found in MLS head gaskets.
NB 3: you must carefully measure piston protrusion, head bolt length and head bolt seating depth in all head bolt holes and carefully compare to the stack height of the head + head gasket. Failure to do so may lead to bolts bottoming out and inadequate clamping of cylinder head to the block.
Price:
$ 395 CAD - cash price, not negotiable.
Please contact me directly at 250 746 8977.
AVOID leaving messages here in the Classifieds Section I DO NOT tend to follow threads on 'Mud.
Do Not Email me... I can not answer all the email I already get and generate labour in my shop so that I can put KD on the table . Please Phone!!
~John
I have
Price:
~John
