105 Series electrical gremlins?
Chatham Islands
Howdy from the Chatham Islands (off the coast of New Zealand) and thanks for having me. I'm running a diesel 1999 manual 105. It's the only one on the Island so have little locally to compare it to. There's only about 600 people living here so getting automotive parts can be a slow and frustrating exercise.
A couple of odd questions that I haven't managed to answer via search:
1) The trip meter(s) reset to 0 each time the ignition is switched off. I assume that's abnormal? Any clues as to where to start looking? In case it's relevant - the door open dash indicator does not light up either
2) I can't find the interior light door switch on the tailgate. The rear passenger doors operate the cargo ceiling light, but the light does not come on when either the upper or lower tailgates are opened. Am I missing something or does the 105 not have a factory tailgate switch for the cargo area light?
Thanks for reading.
Jason
Zeroing tripmeter sounds like weak battery or might poor battery connection.
For the door switch things, if you are handy a bit on using a multimeter, first remove the switches and do a test by pressing and releasing on it.
I do have a European spec 4.7 V8 and I dont remember where the switch is but when back to vehicle I’ll take look and let you know.
^ Thank you for looking for the tailgate door switch location on your wagon.
My 105 series seems to be a poverty specification (which suits my needs as there's less to go wrong). It does have airbags, but has no ABS, traction control, height control, puddle lights... and is probably missing numerous other factory options too.
It's possible Toyota just didn't bother fitting a tailgate door switch to the 105 as I can't find it
I was thinking for your resetting tripmeter…. Due to poor battery connection or weak battery. Cuz when I disconnect batteries it forgets the trip and seat/steering wheel memory as well, I believe you dont have them. Don’t mind the radio station memory cuz even if I remove battery it does not forget them. But I am %75 sure its something related to electrical/battery thing. Give it a multimeter measurements (battery, switch) you should read 12.5V (+-0,25) volts.
If you could not find it, its probably built in with the upper half opening latch.
Can anyone tell me if there's usually an interior light switch on the upper or lower tailgate please, and if so where is it?
Thanks
Thanks for checking that detail for me..
I assume that the cargo area ceiling light is supposed to come on when you lift the upper tailgate? If so I guess I have a minor problem and will need to pull out the rear hood-lining to find and repair the tailgate courtesy light switch. It'd be very helpful to have an operational interior light when i'm trying to unload tools at night
