100 series vacuum hoses and bulk hose
Hi all,
I am looking for a pre-molded vacuum hose 17341-50170, from my research across Japan, Dubai and the US it looks like the part is NLA. Does anyone know if Toyota sells bulk vacuum hose that will match the ID of the hose?
What part is that? I cant even find a diagram for it except on Amayam which shows is grouped as several parts maybe hose clamps ? so maybe that's why u are having trouble finding instead of just the hose
Im sure you can get something from autoparts store to replace it if you cant find oem especially if its just a vacuum hose
Is it from this diagram? I have a 2002 , newer models are different in this area but that section of hose is still available for my 02
Something else to add, if you are just trying to clean up some vac lines that are starting to crack, most of our lines have enough slack to just be cut back a 1.4" or so and cleaned up then re-secured
