ARCHIVE 100 Series Rear Hatch Adjustable Accessory Mount
Will these work with a regular, high-quality cable that uses a straight boot? Not the ring style? I have a LabRak and it most certainly does NOT work:
Hey Dave,
I use it with a 2M antenna and have no CB so I can't say. I want to say yes, since I've had both mounts and the labrak mounting plate was a lot smaller than the KP (which I think is both larger and sticks out further).
I'll try to find out either from the manufacturer or I'll get a cable to test fit for pics. I can offer you dimensions now if you need them.
Hey Dave,
Thanks, don't need dimensions as I had a welder friend replace the top with one 5/8" wider - works fine now and only cost me a couple 6-packs.
I just hope your product comes ready to fit good cables out of the box;)
Nice!
The KP mount does fit straight CB coax cables. The bottom of the mount barely touched the boot on the test fit cable (I suppose it really depends on the thickness of the strain relief incorporated by the manufacturer) but it works fine with your typical width, long, straight connector.
Also, here's a pic borrowed from @Fallon 40 with a straight connector on his dual band antenna:
Definitely show that in your product photos, especially since now I know the reason LabRak didn't have cables in their photos is because they don't work! :(
Hey guys, if anyone is looking for a mount for their antenna or other accessory, we just started carrying the KP adjustable mount. I have it on my truck and it fits and works great. The top mounting hole is slotted so I can adjust the lean forward/backward which is a nice feature. They come bare metal or powder coated but our current order only contained the powder coated version. BOTH PASSENGER AND DRIVER SIDES IN STOCK AND SHIPPING NOW!!! All pre-orders have been shipped.
Kali Precision 100 Series Land Cruiser LX470 Adjustable Accessory Mount
From the manufacturer:
KP offers the best way to mount your antenna/accessory to your 100-series! Our adjustable low-profile rear mounts are 100% bolt-on and they install in minutes. They’re fully designed and manufactured right here in the USA by American engineers and fabricators.
  • Fits both 1998-2007 Toyota Land Cruiser / Lexus LX470 models
  • Installs behind the rear hatch rubber stop
  • Does not interfere with hatch operation
  • 1/2″ hole for CB antennas, lighting, flags, whips, and more
  • 100% bolt-on, no drilling required
  • Large base plate accommodates HAM antennas
  • Can be drilled out to 3/4″ for NMO mount antennas
  • Strong, boxed design with adjustable cant forward and aft
  • Integrated bottle opener
  • Made of 12-gauge HR steel
  • CAD drawn, CNC laser cut, precision formed, TIG welded
  • Available in bare or powder coated finish
  • Powder coated mounts are sand blasted for proper powder adhesion
  • Made in USA
How can I get one of those? Or maybe two of them.... one for each side.
Thanks
