100 Series Project & Info
Awesome Jude which one did you go with?
I got the performance with gas shocks from cruiser parts. They have a 15% off sale on Iron Man right now. I got the kit for $654. The constant load and performance use the same torsion bars the rear springs are 880 lbs (constant) or 660 lbs (performance) over stock springs. I could have got the foam shocks for $100 more. The gas shock is a good around shock and the foam is geared more for high speed washboard type stuff.
Jude you do have a level concrete area to do this right?
jacks tall stands etc
OH! & start spraying with Kroil or PB blaster now & till 8-31-13:D
I have 2 1/4 ton & 3 ton jack stands, 6 ton bottle jack and a 2 1/4 ton trolley jack.
I am checking with the tire guys to use their concrete slab.
Need a swivel head wrench for rear shocks.
I will start stocking the mini frig. Any request?
Sounds nice bud, as Paul said soaking all the bolts down ahead of time pays dividends come wrenching day :) hit those torsion bar bolts good those jokers are long.
22mm
Some posted a regular wrench will work but the flex head type is easier. Some even drilled holes in the floor to get to the nut.
I have up to a 19mm in the set of flex wrenches I have no 22 :(
Jude, I can help after 12.... I have karate in the morning. Oh ... are they welded on or bolt on??
Picked up my stock wheels from Powder Coat Junction. They charged $25 a wheel to sand blast them. I am in for a busy weekend painting them.
Thats not horrible, I'm dropping a few things off to them Monday. They did my front bumper blasting and powder coat and did a good job. I'm looking forward to seeing the transformation after all your work this past month :)
