100 Series A/C restriction issue
Colorado USA
I’m looking for some guidance on diagnosing what appears to be a low side restriction in the A/C system on my 2002 Land Cruiser.
All the A/C components on my vehicle are original none of it has ever been replaced.
About two years ago, I repaired a leak in the rear A/C liquid line underneath the vehicle. After that repair, the system was properly evacuated and recharged, and it worked normally for nearly two full seasons.
This year, when I turned on the A/C, I had no cooling at the vents. I connected gauges and found that the system was not empty, though it may have been slightly low. I added a small amount of refrigerant just to see whether pressures or performance changed, but it made no improvement.
With the system running, I’m seeing the following:
  • Low side pulls into vacuum / negative pressure
  • High side remains around 150 psi
  • No cold air from the vents
  • With the system turned off it takes a very long time for the pressure to equalize high side versus low side.
At this point I’m trying to determine the most likely restriction point before I start opening things up. My main suspects are:
  • Expansion valve
  • Receiver/drier / desiccant failure
  • Possibly another restriction in the liquid side
What I’m hoping to avoid is unnecessary disassembly, especially if there are a few good diagnostic checks that could narrow this down first.
For those who have dealt with this on a 100 Series, where would you look first? Are there any especially useful tests to rule out components that are still operating properly?
I’d appreciate any advice on the most logical diagnostic sequence before I start taking apart the dash side or replacing components unnecessarily.
Thanks in advance.
  • Expansion valve
Thanks in advance.
So I evacuated the system and disassembled the expansion valve and found a bunch of crud that may have been ancient green leak detect dye. I cleaned the valve and plan to flush lines, reassemble with new dessicant bag and charge up the system...maybe an inline high side filter too.
I did not get any response on my post above - I did search for 100 series AC threads but did not find them. Sorry if I posted a question already answered just did not find AC topic easily
I would replace the expansion valve vs cleaning it. How much freon did you pull out vs spec?
