Just to give you an update on the fuel mileage situation. I adjusted the air flow meter on this tank when it was at 3/4 of a tank left. I seem to have gotten more power since I was able to squeal the tires on takeoff afterwards. Not a tire howling scream, just a little bark. I have a wideband o2 hooked up on it and am going real lean after 3400 rpms. You can feel the power drop after 3400. I'm going to flow test my fuel pump sometime by the weekend. I have disagnosed alot of cars that had power loss to to the gallons per minute dropping on old pumps.Doesn't matter if it reads good pressure if it has no flow behind it. Mine has 200k and it may be original. As long as I drive normal my fuel mixture stays ideal till it revs out. This tank came out to 15.8 miles per gallon. Up from 9.7 on the last one. Whew!
