1 More Power Steering Question
nor-cal
Seems to me with a little looking around, you could come up with a lot more pieces of the puzzle for that kind of money....
But that is just me.
Good luck!
-Steve
Wait
I would wait.
You can get a saginaw box at the junkyard for $75.00. Mine came with pitman arm.
You can probably pick up a junk pump to use for a core and get a new reman pump for $50.00.
Figure $50.00 for the pressure hose. This probably high, but I just bought a hose and had a hydraulic shop make up my line.
You will still need two u-joints at around $65.00 each. Pillow block for the firewall $15.00.
I paid about $50.00 for a slip shaft for my column.
Good luck.
JR
Talk to either Mark or Kirk both board members. Both have kits. Your going to need the mounting plates, steering shaft, u joints, pillow bearing, tie rod end and modified tie rod besides what is being offered in the ebay kit. The pump, box and hoses are the more common parts. Do a search, I think there are some Autozone or Kragen part numbers for remanufactured boxs and pumps. A good PNP is also a good choice for these parts. You can have the hoses made. I paid $65 for the pair, custom made out of some very heavy material.
I needed a new Sag pump so I said what the hell. I went to Pep Boys and they had one for $40. I think the only thing you're buying is the conveinence of a kit already put together. These LC p/s coversions can be a whole lot cheaper than $525 but less convienent because you have to search for deals.
Any thought on doing a mini truck conversion? I am running 35" tires and it works fine. I think I have $100 in the whole thing. (Junk yard deals). Just a thought.
Later,
Later,
Unless his truck is a 09/72 or later, the column is going to be a pain in the ass, as he should have the integral steering gear and column, not the two seperate pieces like on the 1973 and later 40's.
:beer:
I have seen PS conversions with solid heavy steering shafts.
Then there is the more expensive collapsible shaft that Borgeson makes. I went with this option. It fits in nice, is not bulky and may save your life in a severe head on crash...
I just don't see the point of going with the absolute cheapest thing out there when it comes to steering...
Max
Hi All:
That is waaay too much $$!
I probably have maybe US$300 into my Saginaw PS conversion, all told. Of course, that includes both new, used, and custom parts, and the assistance of some knowledgable friends!
I would go with the "mini-truck" PS conversion, which you should be able to piece-together for less $$ and is less involved to install than the Saginaw PS conversion.
Regards,
Alan
Well im in the progress of doing power steering on mine and you going to need more stuff then that
Heres a link of stuff and people that help me over pirate
http://www.pirate4x4.com/forum/showthread.php?t=481768
Theres part # and stuff im still not done I just need the shaft that ill be ording tommor on saterday
Do you know how to weld, fab stuff up ???
Eric
