1 banana replacing shocks
Ridgefield, WA
The punch line of chapter 1 here is: what tool do you use to get at the top nut on the DS front shock? I'm a first timer doing shocks and my story goes like this:
Part 1: I randomly start on the passenger side because there's more room to spread out in the garage. Wheel off, bottom nut off with a ratchet and holding the shock body with my hand. I'm feeling pretty good about myself. Then, I can't get the top nut off. The whole shaft just spins. I break down and go get a battery impact wrench from a big box (even though my wife gave me permission to buy a compressor and air tools -- what was I thinking? Oh yeah, I run the finances in this house and no mullah.) With the gun, the top nut comes off and I go to sleep confident I can finish the job the next day in about an hour or less.
Part 2: Next day, passenger side is done in 15 after minutes and I'm momentarily on top of the world, master of my domain. But the driver's side is a whole different ball game. I can't get my gun on top nut due the master brake cylinder. I get one of those whips to make my gun turn a 90deg, but that's no good. A ratchet wrench and vise-grips on the flats of the post do nothing but mangle the soft metal of the post. I finally got the top nut off with a ratchet wrench up top and a pipe wrench below -- stock shocks you can grab a top shroud on the body to keep the post from turning. I get the new Rancho 9000xl in place and the bottom end zips up easy as pie.
However, the top still spins and now there is no upper shroud to hold onto. I can't get the nut to compress the bushing at all so the post doesn't stick up high enough to even try the vise-grip trick. I found a lower profile socket and can get my gun on there with a combo of whip, angle socket adapter and regular profile socket. However, this assembly just shakes itself off the nut and supplies no torque.
There has got to be an easier way. For all the rockstars on this board, I'm sure replacing shocks is mostly trivial. (Though I've read a few posts about the rear shocks giving even talented people fits.) For the driver's side front shock, surely the master cylinder doesn't have to come off. What magic widget do you use?
Your shock shaft is steel. Use a softer metal (i.e. aluminum, brass, copper, etc.) and use a strip of it to wrap around the shaft. Then use Vice grips on the softer metal of choice to lock onto the shaft. The softer metal will NOT harm the steel shaft of the shock. You only need a soft piece of metal about the size of a stick of gum and just wrap the shaft. You will kick yourself when you realize how simple it it. The top of the shock is like a "D" shape. Pep Boys, or whoever, sells a driver for it. Its really stupid and makes no sense but thats what these guys chose as the top attachment.
I happened to have a pair of vise-grips with a big, round opening on the jaws (I had to buy them once to remove an agitator in a washing machine). Anyway, I simply clamped the vise grips on the dust shield of the shock in the fender well and then put a wrench on the nut in the engine compartment. As I turned the nut in the engine compartment, the shock rotated around and wedged the vise-grips in the wheel well, preventing the shaft from turning. A couple of taps on the wrench in the engine compartment with a hammer (couldn't get much leverage on it) and the nut spun loose.
Easy!
NLXTACY: that's a cool trick. I think I have some copper plumbers tape around here somewhere. Do you wrap it around the shock piston shaft? I asked the guy at Autozone specifically for a tool for this job, figuring there has to be one. He didn't know of one. I knew I should have asked the store manager.
IronCladLou: it sounds like you used vice grips in a similar way I used a monkey wrench to take my shock off. And perhaps will tighten the nut by grabbing the piston shaft.
If I remember correctly on the end of the shaft there is a place to put a wrench on to lock the shaft in place, I could be wrong.
A 5/16" open end wrench will hold the top. For the shaft, copper plumbers tape will work fine. Just make a taco shell out of a 4" piece then clamp down with the vice grips.
I tried the 5/16 wrench on my loose shock and twisted the "D shaped" piece right off. Now it goes 'clunk' every time I hit a bump. Where's the eyelet again Mr. T?
Part 3 -- front shocks are on. I tried the plumbers tape and vise grips trick and got about a quarter thread if compression on the bushing before the vice grips couldn't hold enough counter torque on the polished piston shaft. I felt safe driving on smooth roads and my friendly mechanic used his lower profile gear wrench and vise grips on top. Next time I take the driver shock off, I'm going to move the brake mc out of the way and hit it with the impact wrench. What a pita..
5/16" will be remembered for the rear shocks. Thanks. I will be starting on those in a few minutes. Starting with some oil...
Rears a different story. Don't get the upper brackets backwards!!!!
Yup, I hear ya.
Front PS shock is no prob with impact. Rears also a piece o' cake. (yeah, as long as the brackets aren't reversed).
Front drivers side - whadda pain.
I used a right angle pneumatic w 3" cutting wheel, very carefully cut off the nut, shock slipped out - nice.
Do NOT use vice grips on the POLISHED part of the shaft! That is a sealing surface even if you do use the brass tape. Get a strap wrench to wrap around the shock body then use a closed end wrench over and over until good and tight. Reminds me of an old girlfriend... Olga Guttenteight....
Ask shock builders what they do to hold the shaft and report back. It's been happening for decades. Putting a strap around the body doesn't help, it's not going anywhere anyway because of the eyelet so what does the strap gain you?
I used a strap wrench on the body of the shock and a deep socket on the tops. Worked great.
A strap wrench, or pipe wrench, work fine with shocks that have a solid dust cover connected to the piston/post. This is a good argument for staying stock or using something similar to OEM with respect to construction. The Ranchos I'm installing have an exposed polished piston that, as mentioned above needs to keep its smooth surface. The vise-grip/copper strap trick worked sort of The vise-grips started to split the copper, so there is a risk of marring the piston. Perhaps I just need thicker copper stock. I think the stuff I have is 1/32. The flats cut into the top post seem to be the best way to get a hold of the piston. 5/16 or 8mm wrench works well for Rancho. The OEM stocks had smaller diameter pistons.
Part 4: my neighbor kindly lent me his compressor and air impact wrench. Holy cow, I am getting on of these setups. I had the rear shocks off in 2 minutes. I would have had them back on in 15 had A) I seen the warning about keeping the brackets sorted in time, B) remembered the orientation where the flat side mates against the mounting surface, and C) not cross threaded one of the bolts and bolt holes getting carried away with the power of the air wrench. I started the nut by hand and thought it was straight. Whoops. I'm headed to the store to get a tap and a new bolt.
I didn't notice these letter markings until after I had already tried test fitting the shocks several ways. But Mr.T gave us R and L to help us identify which side the mounting bracket goes. The letter should match the letter on the brake assembly.
Any thoughts on cross thread fixes are welcome.
Also, I was surprised that the bracket doesn't sit flush against the mating surface with the shock in place. There is about a 10mm gap on the outside edge of the bracket once the bracket is assembled on the shock and the shock assembly is on the eyelet. I looked at it for about 15 more minutes, after trying all other combinations, and this seems to be the right orientation and bracket. I have the passenger side all buttoned up now. It seems like unnecessary strain to put on the shock piston/bushings though.
Where are they marked L and R? I couldn't find it on mine. And is L driver or passenger for USA vehicles? I agree, there's a ton of sideways pressure on the top bushings. Kinda weird.
The L is on the mating surface, so you can't see the letters when they are installed. In my photo it is in the top left quadrant of the bracket. Bracket is shown under the brake to show both L's. L means driver side for those of us that drive on the Right side of the road.
Part 6: Finale. Got a new grade 8 10mm 1.25 pitch bolt for $2. Also picked up a $30 tap and die kit from Autozone. I tried to clean up the threads with a tap, but the tool is junk and will be going back. The steel from the truck flattened the cutting teeth of the tap. Carbide steel my behind. Anyway, I slowly and with some atf to sub for machine oil, used my new bolt to clean up the crossed threads. It took some patience, but both shocks are on awaiting a test drive.
Thanks all.
Same thing happened to me when I did mine. I used a nylon strap and wraped it around the polished shaft going the opposite side that you are wrenching it to then the end wrap it around the spring to lock it in place boy did it feel like I peeked Mt. St. Helens. I also do it for oil filters that are stubborn, and it won't damage the shaft. Remember to spray the bolt and nut w/penetrant or lubricant for a few minites prior to wrenching, if it doesn't work heat it up a little w/ propane torch. have fun.
ylexot,
I am glad to see you were able to get your shocks on your LC. Coincidentally I was also trying to replace the front shocks on my 1997 LX450 last week when I ran into some trouble with the driver side front shock. I then cruised the forums and immediately came across this thread. Unfortunately I was unable to reply until today because I am new to the forums. Your post encouraged me to become a member even though I have been reading the forums for advice on my vehicle for almost a year. I suppose I owe you a bit of thanks. These forums are a valuable resource in the Toyota fan community.
At any rate, I was able to remove the driver side front shock with a little man handling of the old shock with a pair of vice grips. Another member also mentioned this method. One thing I wanted to add was that I first removed the inferior bolt first. In reality, it broke off as I removed it with a battery powered impact driver. Then I removed this shock from its mount and moved the extended shock medially away from of the shock mount. This enabled the superior bolt and shock stem to move outward away from under the brake master cylinder. I was then able to use the impact driver to remove the superior bolt with the help of the vice grips attached to the shock guard as mentioned by another member above.
The new Rancho RS5000 shocks went on pretty easily afterwards.
I hope your new shocks have made a great improvement on your cruiser's ride and handling.
Regards,
gav
