1 bad TRE - Replace all?
MDarius
I break stuff.
Bountiful, UT
Went for Emissions/safety inspection today and the left outer TRE had too much play. All the others seem fine. I'm replacing the original suspension soon with the OME 2.5'' and plan on changing it out then while I've got everything apart anyways. My question is, should I change all of them (153k miles on original parts) or just the bad one? From what I've read in FAQ and search, to change all 4 is about 2 hours+ if you don't run in to angry bolts and you can do it with a pickle fork as the only specialty tool.
Tips and advice?
Tips and advice?
Replace them all. They have gone far enough and you only want to do this once. If one has reached the end, others are close. It's your steering.
I would not use a pickle fork. The is a specific OTC puller that works great. I have posted the part # previously.
If you live in a rusty spot, it may be easier to get new rods and ends, and avoid the pain of trying to unscrew rusty TREs.
Put antiseize on the threads of the new ones.
x2 for replacing them all.
My '96 has one torn and after asking, the consensus was that I replace all them as the others couldn't be too far behind at 100k miles. I ordered from CDan and IIRC the cost for all four was ~$136 - pretty cheap for such important parts.
I also followed the advice of replacing the tie rod and drag link (relay rod). I went with the Slee products, but there are several very good choices from Mud vendors. Price is $110 each (and they are STOUT). New rods makes the whole job super easy.
Thanks. Cruiser outfitters is local, so no shipping. It looks like all 4 TRE's for under $100. Mine don't LOOK too rusty, we'll see. I started with the WD-40 tonight, I'll do PBlaster tomorrow and until I remove them.
Draglinks too, huh? You're probably right. *sigh*.
153k? Yeah, I'd just do them all. I replaced mine a couple months back at 96k. Didnt have a lot of time to get the job done and had to buy from the local dealership...was significantly more expensive than our awesome preferred pricing through CDan. Just buy all four rod ends and knock it out.
x2 about getting the right OTC tool. $67 I believe, but you'll always own it and can use it for putting that OME steering stabilizer on when you do the lift. I couldnt locate one in time for my job and had to screw around with a small pitman arm puller and pickle fork....it sucked, and eventually I needed another person to help pop the last rod. Bummer.
Schedule a day to do it, order your parts and spray everything down with PB ahead of time. I didnt have any trouble with mine, but I'm in dry/rust free Socal :D
Where'd you all get the OTC tool from? I think I saw the number somewhere (like 6917 or something), but no idea where to purchase.
I just bit the bullit and replaced all of them. I called Bud at budbuilt.com and ordered the rods from him then I called Cdan and oredered the OEM ends. I got all 4 from him for around 160.00.
I needed an aligment and they couldn't align it due to the TRE's being seized with rust. I did it my self under an hour. Just my .02
