1.5 wheel spacers
Las Vegas,Nevada
For those of you that own a 1.5" wheel spacer with 16x8 rims with 0 offset 3~4" lift 315/75 tires
Are you able to stuff your tires without any modifications?
Lift? Shocks? Bumpstops?
I run my wheels at the factory backspacing, when they're stuffed they are right up near the fenders and quarters, no room for more negative offset.
Iirc mine also the last time i looked when it was stuffed.... so im assuming are they
Extending bump stops or rolling fenders to make them fit?
Yes, sorry with 3~4" of lift.
With the factory offset, when stuffed a 12.5" wide tire clears the sheet metal by maybe a half inch. For that reason, you probably won't get anyone to answer the question that actually has 1.5" spacers on factory offset wheels, because it doesn't work. However, I've been proven wrong before.
My 295s barely rub the rear flares at really full stuff with Js and stock bumps so 315s will for sure
Ha, I just dealt with this!
315s on factory rim
1.5” spacers
3” lift
stock front bumpstop
30mm rear bump spacer
factory panhards
Yes they will rip up the factory flares if untrimmed and rub some on the fender at the top on the front axle, and top and rear on the back axle with articulation (from what I’ve found). Needless to say, I blew up my flares, patched, bonded and trimmed. Reinstalled the flares and went to 1” spacers. Tires tuck pretty good with the 1” spacers. If I’m still hitting, I guess I’ll have to lose a bit of uptravel and lower the bumps.
315s on factory rim
1.5” spacers
3” lift
factory panhards
View attachment 1726825 View attachment 1726827
Yes they will rip up the factory flares if untrimmed and rub some on the fender at the top on the front axle, and top and rear on the back axle with articulation (from what I’ve found). Needless to say, I blew up my flares, patched, bonded and trimmed. Reinstalled the flares and went to 1” spacers. Tires tuck pretty good with the 1” spacers. If I’m still hitting, I guess I’ll have to lose a bit of uptravel and lower the bumps.View attachment 1726826View attachment 1726828
Yikes! thanks for saving me the trouble...looks like 1" spacers is the hot ticket.
I’m running Js and 1.25” spacers, and can get a decent stuff without deflaring myself. The app won’t let me upload pics, but I will keep trying.
There we go...from Evans Creek, earlier today
I had issues with rubbing on the stock front bumper, but I trimmed it “aggressively” and no problems since...
