- Joined
- Dec 20, 2007
- Threads
- 133
- Messages
- 1,138
- Location
- Orcas Island in NW Washington State
- Website
- www.mtpickettwoodworking.com
With my T-case all rebuilt and put away under the bench it's time to figure out what to do with this input shaft. This H42 was mated to the case I built, and came out of a '78 FJ 55 I bought here on the island in 1999 to replace the '79 FJ 55 I lost in that year's divorce. Arrrrgh. I have done some searching here on the output shafts and two things stand out.
1)A new shaft is hard to find and very expensive if found.
2) Once a new shaft is purchased, it is just this side of 'no fun at all' to install.
I have been thinking of a different route altogether, and as I try to wrap my brain around the problem, the 'repair' evolves and hopefully improves as I anticipate the stumbling blocks I am sure will arise. Please keep in mind this suggested fix will be used by a 71 year old geezer primarily on paved or gravel roads and rarely exceeding 40 mph. No extreme wheeling. I have made my living as a woodworker for 53 years and have been repairing my landcruisers and ancient ford trucks since I was 19. The last 45years have been on the back side of Orcas island, 12 miles from our small town so improvisation has always factored into my repairs. Last year I added a very nice 12x36 Clausing lathe to my small, heated wing off my 2 bay shop.
My plan started like this. I would like to build an input gear for the transfer gear that bridges across the worn area on the 16 spline output shaft. There are about 1/2" of virgin splines on the transmission side and plenty on the back side of the gear that could be used to drive an altered gear. At first this longer gear was to be made from 3 individual pieces machined and then located out on the long section of splines and clamped tightly by the stake nut. Then the two sides welded to a new drive gear which I bought last winter. My hope is that with this clamping the welds would not pull anything crooked or out of alignment. Of course I would have to source these two internally splined sleeves. I have a pto gear, used but perfect splines that would make one, and perhaps I'd buy another new drive gear for 135.00 to turn down for the other side. But the plot thickens.
All these parts stacked up seemed burdensome and I started thinking about a long internally splined sleeve of correct size. Bore the splines outa the gear, press onto sleeve and weld to suit. They do sell couplers for joining two splined shafts. Haven't found a thing in our size. Oh... how about a slip yoke? Steel versions often list 45.00-65.00 new. I find lots of 1.25 x 16 and even 1.26" 32mm are quite common but these commonly have 27 splines, sometimes others, but never 16. Should I ever find a 16 spline 1.26 sleeve or yoke, AND it had a large enough OD, I could turn it down to the size for the oil seal to ride on, bore the gear to that size, leaving a shoulder to press the gear up to, then weld. And Yes I realize that this long assembly won't fit into the case unless the long side drive sleeve is about 11/16" long, a notch could easily be cut into the rectangular tab at the PTO opening allowing for a longer drive spline. With my one finger typing, the relatively simple machine work involved could be 1/2 done already. If you are still awake after all this, help me find a sleeve or yoke. Thank you in advance.
3) Find another H42 with good splines.
