07 gx470 fuel pump
it looks like my crank no start is the fuel pump. I have accessed the connections under the rear seat but looks like there is no way to loosen the retainer nut let alone remove the pump and float unit thru the access hole. Does the tank have to be dropped? thanks, melz
Hi Melz,
Had my pump replaced and it was done without removing the main tank. U can access the pump from under the car. Just remember fit O ring rubber washer back to connection pipe and use some grease or else the tank starts leaking.
