07 fj
I think it depends or your vin # . The change was done after 50,000 fj's were made . After you install the a-trac switch check it and see if it works .
yes the a-trac wors. do your 285/75-16 rub any. if so what didd you do to fix the problem
They rubbed a little so i installed a toytec 1/2 inch spacer up front and had to trim the body mounts. I used a cutting wheel on a drill and trimed them just a liitle. It all depends on what size 285 and what wheel you use. What brand tire and size are looking at and what wheel ?
