06 GX Windshield Washer Reservoir repair
You would need to figure out the type of plastic and either plastic weld it or solvent weld it. Some plastics require heat welding, others can be solvent welded. The reservoir is likely stamped with the type of plastic.
Personally I'd just find a good used reservoir from a salvage yard. There are a number on eBay for <$100 and you could probably also find one in a local salvage yard.
