For Sale 03-09 4Runner V6 Dual Battery Trays FJC Too! SLC, UT
SLC, UT
For 4th gen. 4Runners and the FJC (newer model FJC requires the removal of the plate with the bolts sticking out of it)
$160 plus shipping (About 10-15 bucks)
Support bracket:
Installed in a FJC:
The pictured tray above is for the Diehard Platinum Marine Group 34M (This is an Odyssey rebadge). There is a separate tray for the Optima group 34.
Here are some photos that should help with placement on the FJC (This is the Optima Tray):
Installation:
Take out the bolt holding the intake hose on there, and install the support bracket.
Slide the tray on in there, bolt in into place...takes all of 15-20 minutes. The bolt we used to connect to the existing hole on the wheel well was a smidgen too long, so it will be replaced with a more snug fitting one.
The install is very much the same as the FJC.
Bump.
Installed in a FJC:
? - Do you know if a Diehard Platinum PM-1, group 31M battery will fit in that spot on a '08 FJC and will the tray work :hhmm:
A group 31 would not fit the tray.
All of the trays have sold. We most likely will not ever make any more.
