02 Sensor Wire Routing help please!!!!
Phoenix
Hi Mud
about 6 months ago a friend roof rat chewed through my Driver side 02 Sensor wires.
I am currently out of money so I have decided to take on reattaching them myself. From the connector coming off of the Driver side 02 sensor I have about 1 foot or so of 4 colored wires, Reconnecting them seems straight forward in my head as I imagine its just color to color...
What I cannot figure out for the life of me is where they connect to, I cant see any obvious split wires coming from the trans tunnel area. Can someone please advise me on where I would find the other chewed through end of the wires?
Post up what you found and did instead of deleting. It may help someone else down the dirt road called MUD.:)
Fair enough. For anyone who faces this problem I had a rat chew through my 02 wiring just above the driver side of the trans for the 4 wires that go from the ECU to the passanger side of the truck but Driver side cat/02 sensor. The passenger side is very obvious as it goes from the cat up to the diag port through the passenger fender well.
The initial big struggle I had was locating where on the truck these wires attached. I spent a good hour under the truck poking around and then from the top side was able to locate the path of the wires. Sitting in the driver side wheel well lift up the mud flap located on the body protecting the wiring/top of the trans there is a two hand size hole here where the wires run. This is roughly where mine had been chewed through.
Starting from the passanger side I fished a piece of mechanics wire over the trans following what I assumed was the path previously based on the wire clip and obvious path over the trans. Once the wire was fished over and out of the right area in the driver side wheel well I taped my 02 wires to my mechanics wire and gently pulled the 02 wires over the trans from the drivers side using my mechanics wire.
This is where I got into the absolutely Sh*tty part. A spent a good 2 hours going between the auto parts store, Cursing and getting dirt in my eyes. I opted for the easy and probably not factory fix, but I chose to get heat shrink butt connectors and connect the wires according to color. There is an Orange, Yellow with red strip, Grey with yellow strip and larger gauge Blue wire. I took my time and cleaned up the wires, connected the butt connectors and heat shrank them. The wires may have had a heat jacket in 93 but none of the run had them when i got to them. So i did my best to apply heat jacket where I could reach. After doing my best to repair and prep these wires I went back to the passenger side and pulled my plastic clip connection back down to connect it to the 02 sensor wire at the plug/clip point. I put some heat jacket on this section of wire as well fishing it as far up as i could. I then put my wire holder clip back into the frame in the obvious point where it lived before.
I fired up the truck after taking a quick Topo Chico and grilled cheese break and WHAM my check engine light flipped off. This was a great victory for me. I am the worlds laziest mechanic and I have been putting this off for a long time. All in all this saved me $500 dollars as qouted by a repair shop here in the Valley of the Sun.
Hope this may help someone with a similar issue, take your time, wear saftey glasses so you dont get crap in your eyes and always remember that someone else out there has done it before you and with enough patience you can figure anything out yourself. God Speed.
