- Joined
- Mar 8, 2015
- Threads
- 9
- Messages
- 363
We installed a set of Doug Thorley Headers back in October. Bank 1 sensor 1 (the o2 on the drivers header itself) wiring did not reach the factory harness. We had to solder an extension onto the sensor. Not an easy task. the wiring doesn't take well to solder. so we had to clean the wires with flux first. About a month later the check engine light came on. It said there was an issue with that o2 sensor. So we bought another replacement. Extended the wires again. Its been 3 weeks (about 1600 miles) and the check engine light is back on. Now we are going to have to get a 3rd o2 sensor just to pass smog (reg & smog is due by the 29th). We are trying to figure out what the actual problem is or if there is a solution. Any one else have any issues? Doug Thorley claims the wiring should've reached. We are 8" too short...
