Conversions of vacuum type case to manual shift:
good for FJ62, HJ60, BJ74, etc etc.....
Acquire entire manual shift lever including stud that screws into side of tranny. None of the shift system from the vacuum can be used.
step 1, deleting the spring forward drive engagement shaft (vacuum uses spring system which is tossed out):
36313-60050 front shaft for forward drive
90254-05004 longer roll pin for fork
step 2, hi/low shift lever change (vacuum is cut wrong and faces wrong way)
36307-60030 lever arm (inside) for high/low engagement
36362-60040 lever top (outside) for high/low engagement
step 3, detent system. Boss is cast on all t-cases and must be drilled out and tapped on vacuum for manual shift. Drill 17/32" hole through boss (as straight as possible).
Tap hole to 15mm x 1.5 pitch. As per FSM assembly, install detent ball-spring-plug at right time
90341-15001 detent plug
90501-14029 detent spring
90360-10003 detent ball
parts are roughly $90 or so in parts from Toyota, the forward shaft being the most expensive.
