Well I've noticed this developing over the last 2-3 months and got really concerned when I read about Cdan's nightmare since mine is leaking from the front end as well. However, I'm pretty certain that it's more likely the front main seal (?) behind the crankshaft pulley.
I realize this is a bit of a loaded question but how common is that on a 1997 truck with around 110k miles, not abused, maintained regularly, blah, blah, blah, but does actually get used like a truck? It seems pretty subtle since it has to accumulate on the skidplate, and other lower hanging stuff before it starts dripping on the driveway.
I've also got a nasty leak around the oil pan that continues in spite of checking the torque on all the bolts. It looks as if that had been dropped before as there is some gasket-maker splooging out along the edges. Not certain about any other points of origin for the leaks but I've got some time that the truck can sit now before I'll need to start driving it again and the mess on the driveway isn't scoring me any points either.
So, my thoughts were to do the oil pan gasket myself, check over any other possible sources for leaks but I'm just not up to doing the front main seal myself right now. Yes, I installed my own s/c, pulled the injectors for service and reinstalled, and have done way too many front and rear axle rebuilds on FJ's from 1974 on but I'm just not feeling up to this right now.
Any advice on how much I should expect to pay to have this done, and if anyone is in southern CA (I live in Riverside) or knows of a good shop/guy that could do this within the next two weeks please let me know. Sorry to go on, just too much on my plate and not enough coffee to make it all clear. Thanks in advance for any help/advice/slaps, etc.
Mike R.
Mike R.
