A better question should have been, where is the pivot bolt on the alt. Do you just loosen bolt on the side of the tension bolt or is there another bolt to unloosen.
Please do not remove the battery and / or tray. No offense to anyone. It's really a waste of time and effort.
Start by removing the front skid plate. Then loosen the AC belt tension lock bolt. Then run down the AC tensioning bolt. Remove the AC belt.
Loosen top pivot locking bolt and tensioning lock bolt on alternator. Then remove the front curtain from your front driver's side wheel well and shine a light in there.
You will see the head of the alternator tensioning bolt. Put a twelve inch extension on your wrench and loosen the alternator tensioning bolt. Remove the belt. Make sure and loosen it all the way so that both belts come off and go back on easy.
Put the alternator belts on and and tighten from the wheel well in increments. Do not over tighten. Without a gauge - press on the belts and they should not have slack over 1/2" with firm pressure.
I have quite large hands BTW and removing the battery is a waste of time - unless - and I may have overlooked this - your truck is stock and has no lift.
On the other hand I can't see this being needed even in a stock truck.
Again - no offense, but you cannot get to the AC commpressor belt lock or adjustment without getting on the ground under the truck. You cannot replace the alternator belts without first removing the AC belt. Please do share.
Do it the easiest way possible by all means but, you cannot get to the AC compressor belt except from the underside - sorry folks, but that is reality....
Hey Tyler - does Rollins make you get a stiffie? LOL!
Go with me here. I'm just f*&kInf with you man...I really like his early stuff. I'm old. I used to see the Ramones, Sex Pistols, Dead Kennedys, etc. live at the CBGB and other places back in the 70's and early 80's.
um, i hesitate to say this but you can get at the alternator adjuster bolt pretty easily if you just undo the 3 bolts that hold the ps pump reservoir in place and move the ps lines out of the way. It is easier with a 1/4" socket but a 3/8" wll work fine.
