more on my tired 8274 (PICS UPDATED 3/22/06)
2020 EDIT: I've moved all of these pictures to my Google Drive, feel free to download them as needed.
i've decided to put this in tech instead of outfitting.
some of you probably know that i've been having trouble getting my winch to work, and i appreciate the patience. i've read the tech article on pirate4x4, but he doesn't really talk about the motor.
PROBLEM:
i can't even unwind the cable 80ft without the winch slowing to a stop. winching myself out of a hole is out of the question. gear assembly on the side is squealing something fierce. winch also won't freespool.
HYPOTHESES:
#1 either the winch motor is dead/dying.
#2 the battery is junk (which i don't think so because the battery was replace
recently and it's still not working).
#3 alternator might not be charging the battery (don't think this is it either. it's a new alternator, and the connections appear to be sound).
TROUBLE-SHOOTING:
sucked the cable in (no load) with a voltmeter on the battery and watched voltage drop from 12v to 11v while winding. the leads me to think that the battery isn't the problem. the motor is quite slow while winding (80ft took about 4 minutes while this winch is rated in the 70's f/mn). over the course of this 80ft no load winding, the winch didn't completly die, but it did slow down over the course of the 80ft.
PICS!!!!!!
click on the link above the pic if you want the super mega large version.
bottom half of the casing. gears look fine, almost no oil in the bottom. the pirate4x4 writeup says 6oz nondetergent 30wt oil. will this stop the loud squealing coming from the left side of the winch? will it help with the free-spooling?
the motor looks dirty/rusty, but as far as i can tell it's ok. i'm hoping someone
who knows motors can tell me more.
pull the freespool knob and it spins easily. this tells me it's somewhere in the lower case that i'm having free-spool problems.
just another view of the top half of the case.
the armature doesn't look bad to me... but what do i know. the brushed in the bottom aren't totally square, but they aren't as rounded as the ones in the pirate4x4 writeup.
any thoughts, comments, ideas, observations would be super great.
i'd like to get this solved in the next coupld of weeks as the cruiser is about
to embark on a 6day desert trip.
PROBLEM:
HYPOTHESES:
TROUBLE-SHOOTING:
PICS!!!!!!
