80 rock lights..I copied WildYoats...
КАГІҒОЯИІА
This may get moved to outfitting, but since it was 80 specific, thought I would put it here first.
Well, I just figured I would show the mounting as I fabricated some brackets out of a galvenized steel 'L' bracket I had laying around.
Trying to broaden the idea horizon here.
Just cut it in half with a grinder, smoothed it up a bit and drilled some holes.
I was not lucky enough to have a couple of random brackets laying around but if you will notice the bolts that go to the frame, they are stock 12 mm Toyota bolts that came out of my '01 Tundra. Can't remember where they came out of but they were laying right there in the corner of my workbench, slapping me in the face. Fit like a glove.
I still have to order a relay and the switch that Mr. Yoats has but you get the picture.
Looks good! :)
what're those things hanging down under your bumper? wires?
NorCalDoug said:
Looks good! :)
Yea, I just used some alligator clamp jumpers to give them a tester.
The sun was going down and since I do not have a garage... I had to give it up for the night.
Looks sloppy but it will be zip-TIGHT when finished.
