Help! Lost #2 cylinder
E. Washington
Guys at autozone threw the code reader on my rough riding '99LC today and said my #2 cylinder wasn't working. What could it be? Plug? Wires? How do I trouble shoot? He was talking about pulling the plug out and seeing if it would fire. I know you can do this with spark plugs, but my knowledge on these new fangled high tech rigs is limited at best. Is this something I can trouble shoot and fix or should I just bite the bullet and take it to the dealer?
Thanks,
Jeremy
I've had the rig for the last 10k or so and never replaced the plugs. I guess I'll go yank it off and see what it looks like. The #2 plug is the front passenger one right?
Cyl 2
Yes, front pass. side. How many miles on it? Could be a loose connector from previous starter contact job or coil removal. I broke a couple of the brittle plastic clips for the injector connectors when removing the intake manifold.
Fault code Cyl. #2. Was it "P0303" cylinder not firing? If it's not the sparkplug, then check to see if the coil has cracks or shows signs of tracking. Swap #2 coil with #4 coil, clear the CEL code by temporarily disconnecting the battery, and see if it throws another CEL, P0305 meaning the original #2 coil is bad.
Put a stethoscope on the injector while it's running and see if it's clicking or if the loudness of the clicking compares to the other injectors. A quiet injector is not healthy.
If none of the above, switch sparkplug #2 with #4 to see if the fault follows the sparkplug.
Also check continuity in the plug wires. One time I had an internal short in a plug wire in my 4runner.
Me thinks its a coil pack...
I sell 2 or 3 a month for the Toyota V8s...
A coil pack was the culprit. I need to get a manual for this thing so I can so some more work on it. I had them replace it and clean the throttle body but said no to the $215 spark plug job. I think I can manage that without a picture.
...I hate it when I am right.... ;)
