Just wondering if you guys might know what to call this. It is a 5 speed toyota transmission with a fine spline B input shaft but it has a solid one piece transfer similar to 74-8? The front half looks identical to an H41. It look like a H41 or 42 with the spacer out of a 60, but this one has a shift fork in the rear making a total of 3 forks as you can see. It is has landpimps logo stamped a couple times on it(Teif??) never did figure that one out. There was a discussion a while back about these transmissions but I just got my hands on this one this week. Any ideas?
Here is the transfer that I pulled of the transmission. The transmission does not look like any h55 that I have nor does it look like any of the H41s. It is close but not the same. Thanks
Do you mean a H50?
I was going to suggest that myself but Ive never seen a Dyna box that has a gearstick that fits to the top like a cruiser.They also only have 2 forks and another small fork for reverse.
All the Dynas and Coasters Ive ever seen or owned had the shift linkages exiting from the LH side of the plate and winding their way to the driver via the most complex set of shift linkages I have ever seen.
They must do it this way because the driver sits over the front of the engine and too far forward to reach the gearbox.
Of course the newer Dynas have the driver sitting further back to improve safety so maybe its off a later model Dyna/Delta
