Toyota extended diff breathers
Chesapeake, VA
Website
theshealys.com
this is what I found at the dealer. This is a print out they gave me.
I ordered three 42306f(the upper plug). I allready have 42306A installed
Don't know the part numbers but I ordered upper breathers off of the UZJ100 Cruisers and used 3/8" hose to the factory lowers- works greats. With absolutely no leaks.
total for front and rear axle with 5 ft. extended breathers-
upper breathers- 6.85ea
10ft hose- 9
four clamps- 1.79
The breather plug that accepts the 1/4" hose is $10.20. On the receipt, it says it's part # 90930-03097 and the picture shows 42306f. I'm just hoping to help someone find a few parts. The main reason why i'm extending my axles is that I want to reduce corrosion. I can't ever tell if my plug is clogged or not. Do you guys put the plug in your mouth and blow? I might keep a small piece of 1/4" hose to use as my mouth piece.
