Subject says it all... Does anyone have one of these rare (I assume they are rare), setups?
Anyone know when/where they were actually available?
FJ40Jim said:H55 came out in 1982. One piece case was replaced by split case in 1981. It doesn't seem the two would have ever been mated from the factory.
bcon said:This is all an I think....
I think some of the 5 speeds that came out of Dyna trucks have the one piece transfer. They are toyota 5 speeds that are best described as an h41 with an add on piece on the rear with the 5th gear there. The transfers I have seen bolted on are a "4spd" Tcase like out of a 74+. As far as the donor vehicle, "I think" its a Dyna. If you want one PM. Hope this helps and GL. Eric
FJ40Jim said:<shrug> I dunno. Seems strange to produce the old 1-piece case concurrently w/ the dimensionally identical but much superior split case. Perhaps the picture in question is not Cruiser stuff, as you said? On the Mitsu Fuso FG trucks (equivalent to 6x6 Dyna), their Aisin T-case looks just like a Cruiser case, but bigger.
cruiser_guy said:As for bolting the H55 to a single peice case, and having a working assembly, you'd need a 16 spline H55 or a set of 19 spline single piece case gears and I have not heard of either...
