I think I &@!$ up on this one; engine cranks but won't startup anymore. Here's what I did to cause problem: I removed the inoperable alarm system; wires and all. Two of the alarm wires were spliced into the ignition harness, so upon taping them up I accidently touched one of the wires to ground. Stupid me forgot to disconnect battery as a precaution. Anyways, after taping up the exposed wires I went to start it up and it won't. I checked all fuses and relays and they are all good. I thought grounding the wire would have caused one to blow but nothing. Here's the scary part, with the ignition in the on position I noticed the check [engine] light doesn't come on; this should right..? I did some voltage tests based off the FSM at the ECU end and only getting power to ECU, but nothing else. Did I blow the ECU? Is there something that I missed in my diagnosis?
Your help is appreciated,
Carl
Carl
