Could somebody please elaborate on a couple of things since I'd like to determine if mine is OK without losing a finger and I think this may be helpful to others as well:
- this start-up whoosh, this is something beyond the fact that the rpms are higher for a few seconds when you start cold, right?
- after the whoosh subsides with a cold engine, how long does it take for the good fan to start cycling, and how fast is this cycling?
- this new finger test, unlike Robbie's, is to have the engine start, wear a glove, and bring your fingers slowly in contact with the fan to see if it slows down, correct?
- perhaps most importantly, could somebody with a bad clutch (Curran?) and with a good one (CDN?) try and see what level of resistance there is if you try to turn the fan with engine stopped?
With this info, I may try to start measuring air velocity and maybe even fan velocity.
TIA
