Homemade!
so I want alot more than my wallet can handle....so the idea of making some of these toys myself popped into my head
I want to make:
A roof rack w/ladder
a gas can holder
extended shackels
assorted toolboxes
the list goes on and on...
So I would like to see some of the homemade carzyness from the guys in here or at least hear about it, of course pics are the best but anything will be welcome...I'm looking forward to some different ideas
Thanks
Brandon
Brandon, Here's a picture of the jerry can holder I built! It's 3/4 square tubing, a piece of sheet metal where the liscense lamp and plate are mounted, the entire rack is hinged on early tire swing out hinges, and 2 piece latch assy. , the side that faces the truck is the side that opens, has a latch, and bars that won't let them be stolen. I hope the pictures make sense to you, Earl
Now this is the stuff I'm talking about keep them coming, and yes Earl the pics are perfect did you make that roof rack?
Thanks again
Brandon
Brandon, I think the roof rack is a Con-Fer item, but I'm not sure. Earl
Roof rack: 3/4" EMT (7/8 OD). Cheap, easy to weld, and strong enough to carry two spares, 80lbs of water, 100lbs of petrol, 100lbs of gear, two sheets of plywood, and a canoe. :D Confer mounts.
Imageshack
Macgyver5 said:
Sweet ridgerunner do you have any better pics of it?
No, not really. Here's an overall (with a hi-lift, jack, and a bag on trash on it). If I was to do it again, I'd weld in some more perpendicular braces that would run the length of the vehicle (someday I will.)
Imageshack
So this can't be it...I mean don't get me wrong these are awesome it's just hard to belive that with all of the crazy wheelers and rock crawlerz on this forum that this is the end of the road for good ole back home invention....there has to be more....and to the guys who have already posted I thank you the examples that you've givin are exactally the type of things I was looking for...I truly appreciate the craftmanship displayed!
OK, here's mine. Its not the kind of picture that shows the rack construction details but it does give you the general idea of what I did:
Right Rear rack holds Action Packer, 1 or 2 Jerry Cans, or 1 Jerry and 1 Water and swings out. I have several way to configure this swing out rack making it "configurable" for the trip I'm taking.
Left Rear is stock Cruiser and holds tire. Also have add-ons for this side to hold another Jerry can behind tire as well as a small BBQ.
At tub level, there is a platform for cooler and camping gear... Below this deck is spare parts, tools, and other heavier gear.
No roof rack for me. Too heavy.
Disadvantage is I have no rear seat with the platform design. Usually, this is not a problem for me.
Did you build that yourself Mike?? That's a cool trailer!!! Please, more info on the trailer!!
Jody.
