Navi system pixs
Hopewell NJ 08525
I got some pixs that fit now :D
This is the system (2005 camry unit) from www.oemvalue.com that they happen have been soldout at this moment :flipoff2:
Very nice, and good screen size, and clean install. Can you download maps from your computer into the unit?
LX_TREME said:
By the way that system from '05 camry unit cover the whole U.S regions or just some state? Also comes with Voice intelligent system?
With it being DVD-based, I'm sure it covers at least the lower 48, if not Canada, too.
Todd now I know that you live in the sticks according to the screen shot of the Nav.
The system covers the US and Canada but Im not sure how much .
You can add the Voice mic and it will learn but I didnt get it but i did order the XM unit for it from Cdan to replace the one I have in the center console :bounce:
LX_TREME said:
Tech Tip: Just to be safe you might consider the voice activation system, you dont want keep lookin at the screen while you drive heh? :eek:
The unit wont let you change the Nav setup unless your stopped . It knows like big brother :D
I let the cruiser :princess: run it if needed
Koffer- there is usually a wire you need to ground or tie high to hack the "disabled while moving" "feature". Search the web for your specific system. My installer (for the Alpine I unit have) did this for me.
I there an external antenna for the unit? If so where and how did you mount it.
Thanks,
Steve 94
Looks Great!
Hey Todd,
Thanks for posting these photos up, install looks great. I've long been interested in how well this install would go, since the dash opening is a little small. Any insight on how difficult it was to make it fit cleanly?
P.S. -- OEMVALUE shows the Camary systems in stock again (currently, it changes overnight it seems).
The system hooks into the speedo and if I diable it I loose the "time to local" and some of the other things which I would rather have
best4x4xfar said:
Hey Todd,
Had to cut the sides of the dash opening but it wasnt bad at all just kept test fitting it as I went so I didnt end up with a hole that looked like I used a sawzall on it :doh:
