lots of stuff
Bozeman, MT
lots of stuff for f and 2 f engines
I have all this stuff which needs to go.
f engine flywheel
2 clutch pressure plates
2 clutch forks
1 air filter housing
4 rocker arms and a couple push rods
1 crankshaft nut
some engine mounts
Water pump free if you want to try and make it work
fuel pump
fuel tank filler neck for a 55
oil pump
thermostat housing
3 pulley wheels
valve cover
oil pan thats dented free if u want it
3 spare rims
a bunch of gaskets most of which I dont know what they are
set of piston rings
bearings for the pistons and rods
2 intake and exhaust manifold sets
73 2barrel carb with all the linkages
70 2 barrel carb might be good for rebuild or parts
emission system for a 55
stock shackles for a 55
brake master free if you think you can salvage anything from it
intake from the pre 67 f with header that was chopped off
Make a reasonable offer for anything and its yours.
Forgot an item I have the rear heater from an fj55 with some surface rust but in working condition fan blows well.
Orange $25 for all 3 pulleys both the forks and the spacer.
66fj40x2 I'm not sure of the years I'm gonna say at least one of them is a 73 though since thats what my cruiser is and thats what a lot of the components in it were.
rgentry I dont really know what they are worth specter says 250 but thats a load of crap so just pm me a reasonable offer. Travel down to kennesaw with my gf occasionally.
66lwb45 I dont really know what the bearings are I believe 1 set is for the pistons they just say engine bearings on the box from specter. The other say bearings, con so I'm assuming that means connecting rod? As for the intake/exhaust manifolds same thing I told rgentry i have 2 sets and 1 extra intake.
I'm a big fan of paypal, Send the money to rrudnic@clemson.edu once I ship I'll quote you the shipping cost and you can send a second payment for that. I'm horrible at guessing weights so its just easier for me to ship it and get a second payment.
If 66 posts or pms me that he wants a fork then I'll go ahead and hold it out for him otherwise I'll just ship them both to you.
The bearings are both .010 under just so you know and I would like $25 for the 2 sets they are still wrapped in the plastic in the boxes. And another $20 for the rings. I havent even opened the boxes on them yet.
Always looking for a good deal on carb cores.
Also interested in the manifold sets. If I'd have known about these when your ordered the set from me, we could have worked something out.
The 70 carb does have the accel lever but its the one thats in not as good of shape. I really dont know what these carbs are worth. Maybe Jim C could give us a little hand with prices. Several guys have said they wanted manifolds but nobody has made any offers or sent any pms so if your interested just let me know. And as for the other carb I want good money for it because it has everything there and I think its good enough to run right now. However I'm not sure how much that is either so once again some help from Jim C would be good.
clutch stuff
really interested in all of your clutch stuff. do you know how worn it all is. If they are not horrible then ill buy it all. Don't really need the forks so that no big deal. If you have everything to pretty much switch out a clutch ill buy it. Thanks in advance
Merc
