Having had fitted brand new central diff lock actuator by a mechanic. Thank you so much Dan. The mechanic told me my centre diff lock was now working! On return to my property were the environment is more than suitable to check out my new found traction I get stuck, I flick the CDL switch and sit back with smug confidence while I still remain stuck. I ask my wife as it is raining heavily to investigate which wheels were spinning. After a lot of bending and staring at the 4 corners of the 80 she came over to my window and declares that the rear left is spinning on its own. “No” I replied “go and look again” as it now needed 2 wheels, one on each axel to stop us, as the CDL “is working”. “One wheel spinning” she reported again. “s*** ****” I said. I confirm my suspicions by looking at the dash no CDL light no ABS light.Question, I am now little frustrated what next needs to be investigated? On ringing the mechanic he tells me that he thought it was working but he only investigated this by putting his finger over the top to feel if it was operating???
I would very much appreciate some advice here as the ground is getting very slippery now and I am totally reliant on the lockers working especially when the weather gets worse or I will be having to get in and out by tractor.
